name that clunk!
Old Mar 2, 2012 | 06:36 PM
keithdphan's Avatar
name that clunk!
my 1989 pickup makes a clunk sound when accelerating from a stop. mostly happen the first thing in the morning, and it gets better but does not totally go away as I put in 15miles of stop and go traffic. clutch or u-joint? i'm thinking u-joint.
Old Mar 2, 2012 | 07:05 PM
ksti's Avatar
I'm guessing its a manual trans, Check u-joints first and then if there are zert fittings on them then grease um up and see what she does. Good luck I hope its a simple fix.
Old Mar 3, 2012 | 07:50 AM
arlindsay1992's Avatar
Other things to check are engine mounts. Then suspension parts/bushings etc. I think the driveshafts and engine mounts are more likely but check everything.
Old Mar 4, 2012 | 04:47 PM
keithdphan's Avatar
so ive crawled under the truck and checked out all of the u joints on the draveshaft. all of the joint except one seem to be fine, ie no play by hand. the suspect one (closest the the rear diff.) had a tiny bit of play in one direction. this amount of play was able to give off a clunking noise by the way.
my question is what is the acceptable amount of play to we within factory spec. for u joints? is my suspect u joint within spec? is this a must repair now? what can go wrong if i dont.
thank in advance yotatech.
Old Mar 5, 2012 | 02:05 PM
Stuwy123's Avatar
U-joint or wrong wheel lug nuts.
I've had both problems.
Both my a very similar click/clunk sound.
The wrong wheel nuts make a ridiculous pepper grinder noise going around corners.
Old Mar 5, 2012 | 03:09 PM
Good thought with the lug nuts. More likely to be a problem on alloy wheels.
runnygirl19
Nov 19, 2015 11:39 PM
Naween Zohab
Nov 10, 2015 03:56 PM
BK2TFUTURE
Oct 11, 2015 08:42 PM
Odin
Sep 26, 2015 06:56 PM
altydog
Sep 20, 2015 07:37 PM
