name that clunk!
name that clunk!
my 1989 pickup makes a clunk sound when accelerating from a stop. mostly happen the first thing in the morning, and it gets better but does not totally go away as I put in 15miles of stop and go traffic. clutch or u-joint? i'm thinking u-joint.
so ive crawled under the truck and checked out all of the u joints on the draveshaft. all of the joint except one seem to be fine, ie no play by hand. the suspect one (closest the the rear diff.) had a tiny bit of play in one direction. this amount of play was able to give off a clunking noise by the way.
my question is what is the acceptable amount of play to we within factory spec. for u joints? is my suspect u joint within spec? is this a must repair now? what can go wrong if i dont.
thank in advance yotatech.
Odin
Sep 26, 2015 06:56 PM
