head job gone bad
Old Jun 28, 2005 | 12:38 PM
dougm395's Avatar
Question head job gone bad
my 91 toyota 3vze had a burned valve. i had another engine i removed the heads and delivered them to the cylinder head shop.when i picked them up he did all the usual and set the valve lashings.when i reassembled my engine the it ran like crap. (i.e would not idle, backfire through the intake). i triple checked my timing and its perfect.my muffler ig getting extremly hot at idle.what could it be.
Old Jun 28, 2005 | 12:41 PM
jimbo74's Avatar
did you check the timing with the connector terminals shorted?
Old Jun 28, 2005 | 01:27 PM
Wildcat_4R's Avatar
Stuck intake valve? Have you checked compression? Not too familiar with the 3vze but is the timing belts setup correctly on the pulleys? If it was me, I'd double check that stuff first. Good luck.
Old Jun 28, 2005 | 01:32 PM
seaflea's Avatar
Maybe you got a couple of plug wires crossed.
Old Jun 28, 2005 | 01:48 PM
marko3xl3's Avatar
I just have to mention that the title made me laugh, I am sorry, move on ...
Marko
Old Jul 4, 2005 | 07:04 PM
MTL_4runner's Avatar
A backfire usually indicates a timing problem.
Check the timing belt and distributor timing (firing order and advance) again to ensure you didn't miss something.
Old Jul 4, 2005 | 09:03 PM
BruceTS's Avatar
simply put your timming is off......
Old Jul 5, 2005 | 07:00 PM
kyle_22r's Avatar
backfiring could most definitely be caused by an intake valve that's stuck or doesn't have enough lash(and thus is staying open)
Old Jul 7, 2005 | 11:19 AM
95ToyotaPU007's Avatar
Marko
thought the same thing...
"simply put your timming is off......"
maybe her timing is off...jk.
Old Jul 27, 2005 | 11:16 AM
dougm395's Avatar
ok i solved the problem it was a leak in the intake gasket
Old Jul 27, 2005 | 06:19 PM
kyle_22r's Avatar
bloops! i've made that type of blunder before. after i swapped in my 20R head, i fired it up and it ran like total crap. yanked out the timing light and it was a *little* off but setting it to spec didn't help.
ended up, i noticed that i had forgotten to connect my brake booster line. doh!
bigjstang
Jun 2, 2025 03:56 PM
icentropy
Sep 16, 2020 02:47 PM
jasonty
41
Dec 23, 2018 01:00 PM
Fundy Rider
Jul 16, 2015 01:35 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
