brake lights and bulbs not working
my break lights on my 95 4 runner are not working ive checked the fuse and really cant figure out whats wrong with them. any idea what could do the trick to get them working again. if not how much do yall think its gonna cost to fix them bad boys?
If you have a multimeter, you can check for voltage in the lamp socket directly, and at teh switch. After that, it's a matter of tracing the wires. If it's just the bulbs, I'd strongly reccomend LED's as replacements. They use a LOT less power to operate, and they last about forever. Most are tested out to over 10,000 hours of continuous use. They're more expensive, but since chances are you'll never have to replace them again, they pretty much pay for themselves.
Also, make sure the grounds are good. A dirty socket or broken ground wire can cause the lights to not work also.
Good luck, and keep us informed!
Originally Posted by jtm994
alright tried the swich but they work when i put on the headlights so its not the bulbs they just dont work when i apply the breaks.
if that goes out your brakes work but they won't light up......
Also, the brake lights are NOT the parking/driving lights. You have 2 different filaments in the same bulb. One energizes for the parking lights, the other when you step on the brake. Just because the bulb lights up when you turn the headlights on means nothing. It's entirely possible to fail the brake filament while the other is perfectly good. Make sure your bulbs are actually good for the brake filament, not just the parking light filament.
Aleeex_u
Jun 5, 2016 06:52 PM
LSUMatt1514
Jun 26, 2002 05:03 AM
Leonel
Jun 13, 2002 02:42 PM
