Signs that block is cracked
Old Jun 30, 2005 | 06:22 PM
spiderx's Avatar
Hello everyone
I have a 88 v6 3.0 extra cab pickup and the other day the truck overheated and oil was pouring out of the rad. There were no signs that the head gasket was on the way out at least thats what I gather happened. My question really is are there any other things to look for to suspect a cracked block? I drained the oil and its pure (no water). Any help would be great!
I have decided to replace the head gasket myself.
Old Jun 30, 2005 | 06:36 PM
Bigblock's Avatar
its the headgasket!
Old Jun 30, 2005 | 08:29 PM
dragon564's Avatar
Steam clean everyting that you can see on the block.....get all the grime off.......then fill the fluids to the correct levels and run the truck for a few minutes to let it warm up.....look for fluild leaks......That or pull the motor for the HG work and send to block in for an acid bath......they will let you know if the block is wasted or not.....
Old Jun 30, 2005 | 08:32 PM
ChickenLover's Avatar
It's more than likely a blown head gasket. I seriously doubt it's the block.
Old Jul 1, 2005 | 05:36 AM
spiderx's Avatar
thank you
I bought the gasket kit and am taking it apart today.
Old Jul 1, 2005 | 06:06 PM
spiderx's Avatar
right side is covered with oil
I have never done this before but its not that bad
Old Jul 2, 2005 | 08:51 AM
Yota4runner's Avatar
Just remember to take your time, label things, and take lots of pics
Old Jul 2, 2005 | 09:58 AM
spiderx's Avatar
Thanks for the tips
I still love the truck after 10 years and will try anything lol
If I get stuck I will post
Old Jul 4, 2005 | 01:27 PM
spiderx's Avatar
does anyone have the Cylinder head torque specs. I can't seem to find them
Old Jul 5, 2005 | 06:42 PM
calisurferdude2000's Avatar
Step 1. 33ft-lbs
Step 2. Turn additional 90-degrees (1/4 turn)
Step 3. Turn additional 90-degrees (1/4 turn)
Old Jul 5, 2005 | 06:54 PM
spiderx's Avatar
thats funny the existing ones were at 60ft-lbs and I have been driving for ten years.
Old Jul 6, 2005 | 02:45 PM
That's what the Haynes manual says.
Old Jul 7, 2005 | 11:17 AM
spiderx's Avatar
thank you
Old Jul 7, 2005 | 06:34 PM
spiderx's Avatar
k got it back together and it runs
but lumpy on low speed and great in faster speed. could this be the timing?
Old Jul 8, 2005 | 07:52 PM
stockrocker's Avatar
could be timing... any knocking? my buddy had a similar problem, he didnt have a valve lined up with a rocker and had to get a valve replaced..
Old Jul 9, 2005 | 05:08 AM
spiderx's Avatar
no knocking
I have read somewhere that it could possibly just be the spark plug cables or a vaccum leak I'm going to test it today
Corvoid
Jul 4, 2021 11:51 PM
Marsheen
Feb 17, 2016 12:29 PM
Gravel Maker
RuffStuff
Aug 27, 2015 12:23 PM
A2theK
Jul 12, 2015 10:46 AM
horunner1x
Jul 10, 2015 06:33 AM
