Why won't it start
Old Jul 30, 2005 | 07:46 AM
supagirl01's Avatar
Why won't it start
We replaced the fuel pump, and the starter. Still starts when it wants to. 1991 4runner. Also bought a new battery. Alternator is ok. It seems like it's something between the ignition and the battery in the wiring?! We're about to go crazy trying to figure it out. The wires are like a bunch of spaghetti. I really appreciate if anyone has any suggestions. Thanks a bunch, Christy
Also, we found a sending unit unattached. Does anyone know where it goes?!
Old Jul 30, 2005 | 08:08 AM
90's Avatar
90
Have you checked for trouble codes ?
Use a short wire , connect terminals TE1 and E1 of the data link connector , turn the key on but don't start. Push the OD button in. Watch the CEL and OD lights.
Old Jul 30, 2005 | 09:02 AM
94x4's Avatar
Guest
What sort of sound does it make when it does'nt start ?
Where was the sending unit that you found located ?
It could be the contacts in the ignition switch itself. You can try removing the trim panels from around the steering column to expose the ignition switch and with the doors open and the truck sitting outside for good ventilation, hold a rag or paper towels under the ignition switch, and cover the surrounding areas to protect against overspray and dripping, and hose the ignition switch down with a complete can of CRC QD Electric Parts Cleaner (make sure it's the "QD" type.
Afterwards, while holding the "straw" attachment to/into the keys' slot, lightly spray it with a silicone lube to relubricate it.
Let dry for a sufficient amount of time and see if that solves the problem.
Old Jul 30, 2005 | 09:23 AM
toy_tek's Avatar
Possible neutral safety switch - probably on the clutch pedal.
Sounds like you're shooting in the dark between electrical and fuel. More details on the problem, please.
Old Jul 30, 2005 | 09:41 AM
supagirl01's Avatar
There isn't a CEL though
supagirl01's Avatar
It's got a brand new ignition switch too. Thanks though.
Old Jul 30, 2005 | 09:43 AM
supagirl01's Avatar
It's an automatic. It usually starts right up in the morning. It seems to be most problematic when it's time to go home from work around 5 PM for some reason. I get a jump and it starts right up.
Old Jul 30, 2005 | 09:46 AM
toy_tek's Avatar
What EXACTLY is happening when it won't start? Clicking? Cranking? Nothing? Any lights? Weather conditions?
Old Jul 30, 2005 | 09:50 AM
supagirl01's Avatar
It clicks and all the lights work. Nothing weather related affects anything.
Old Jul 30, 2005 | 09:54 AM
toy_tek's Avatar
Sounds like something is draining the battery. What is the voltage reading while running? When it is shut off? 8 hours after shut down? Do you have an ammeter?
Old Jul 30, 2005 | 10:29 AM
mtnfreak's Avatar
Sounds like you've got the same problem I used to. Starter would act up when the air temperature was warm. Seems to have been a problem with the wire running to the starter being old & building up resistance. I put in a starter relay using the tips from 4Crawler on THIS PAGE. Go down to the last section on the page. I didn't use any fancy parts - just a 30 amp relay from Radio Shack and some wire and connectors I already had.
Good luck.
Old Jul 31, 2005 | 05:31 PM
dragon564's Avatar
I would also look at the starter...after all it is 10 plus years old.......
Old Jul 31, 2005 | 09:01 PM
2ToyGuy's Avatar
It's also been determined that a surprisingly small amount of dirt/corrosion where the starter bolts onto the bell housing can cause this problem. Blocks the ground part of the circuit. Something to look at...
Old Aug 1, 2005 | 01:07 PM
4Crawler's Avatar
Have a look at the web page below for some troubleshooting and repair ideas:
http://www.4crawler.com/4x4/CheapTricks/Starter.shtml
Old Aug 2, 2005 | 08:18 AM
94x4's Avatar
Guest
Maybe it's just a matter of a loose connection or two and you need to tighten something down..., or..., you're a "hot" girl and someone at and/or around work has got it hot for you and is shorting your car out so that they can play the "knight in shining armour" (pun intended) routine and come to your rescue so that they'll be able to start up a conversation with you to help them get over their initial shyness??? You never know.
p.s. I've got to stop watching those damn cutesy, "girl" flicks!!
sandyota
Feb 4, 2021 11:16 AM
raiderhawks00
Jul 8, 2015 06:23 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
karbin
Jul 5, 2015 11:37 PM
