Squealing at Idle
Old Jul 19, 2005 | 02:27 PM
hutch24's Avatar
Squealing at Idle
I have a 92 pickup with a 22RE, lately it has started squealing at idle but only when the engines warm. Any ideas what it could be?
Thanks,
Bryan
Old Jul 19, 2005 | 03:49 PM
94x4's Avatar
Guest
Loose belts and/or low power steering fluid.
Old Jul 19, 2005 | 03:54 PM
hutch24's Avatar
The belts are tight. Whats weird is it will only do it when its warmed up and it only does it at idle.
Old Jul 19, 2005 | 04:37 PM
truckmike26's Avatar
Check the power steering fluid level and then bleed the system.
Old Jul 19, 2005 | 05:53 PM
94x4's Avatar
Guest
Yeah, uh, ditto.
Old Jul 23, 2005 | 06:55 AM
4Crawler's Avatar
Might also check the idler pulleys on the p/s and a/c (if you have those options). Easy check is to loosen the idler and feel the pulley w/o the blet on it. Should spin smoothly, if it feels gritty or is loose and wobbles, the bearing is in need of lube or replacement.
Blamalam
Mar 12, 2022 07:34 AM
lmobeats18
Aug 28, 2015 04:57 PM
AppalachianOffRoader
Aug 12, 2015 12:55 PM
RBK
Aug 2, 2015 11:33 AM
PlayAwhile
Jul 20, 2015 11:36 AM
