How do i change a 2nd gen tstat
Old Apr 26, 2004 | 12:22 PM
nm4runner's Avatar
Question How do i change a 2nd gen tstat
i tried searching and didnt find anything, i did find the 3rd gen write up but it looks different than mine. 2nd gen 3.0 iam getting a new radiator and what to change everything while its apart...thanks
Old Apr 26, 2004 | 01:16 PM
eric-the-red's Avatar
The thermostat is located where the lower coolant hose meets the engine. There are 3 bolts holding the cover on. While the rad is out is a good time to do it, it's a lot easier to get to.
Old Apr 26, 2004 | 02:41 PM
Robinhood150's Avatar
Rather than retype everything, here is a link to a good thread: Click
Old Jan 29, 2011 | 09:39 AM
jjearl's Avatar
which type of RTV is best?
Old Jan 29, 2011 | 10:08 AM
mt_goat's Avatar
For what? Our Toyota t-stat uses a rubber gasket. But for an RTV used to seal around coolant I use this:
Old Jan 29, 2011 | 01:48 PM
jjearl's Avatar
i have the 3.0 first gen 4 runner. i bought a thermostat (jiggle valve) and a rubber gasket. the haynes manual says i need a room temperature vulcanizator to seal it up.. wich one is best?
Old Jan 29, 2011 | 02:21 PM
mt_goat's Avatar
I wouldn't go by anything a Haynes manual said, why would you use that with the FSM available here? http://personal.utulsa.edu/~nathan-b...fsm/index.html
Here's the T-stat section: http://personal.utulsa.edu/~nathan-b...10thermost.pdf
Old Jan 29, 2011 | 02:24 PM
camo31_10.50's Avatar
what the HELLLLLLL is a room temperature vulcanizator......that sounds like space weapon from some gay B-movie
Old Jan 30, 2011 | 11:07 AM
jjearl's Avatar
thanks for the link man. cuda saved me $20 hahahha
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
the1998sr5
Jul 16, 2015 06:20 AM
Steezy96yota
Jul 6, 2015 10:00 AM
HRDC0R19
Jul 5, 2015 06:43 PM
