installing oil pressure guage, will the light stay on?
Old 08-10-2005, 04:12 AM
brendonv's Avatar
Im going to be putting in an Auto Meter oil pressure guage, if i just remove the stocker oil pressure sending unit and replace it with the new one, will the light stay on?
Old 08-10-2005, 09:20 AM
Guest
94x4's Avatar
Why not hook them up together? That way you've got a secondary or failsafe.
Old 08-10-2005, 09:54 AM
4Crawler's Avatar
Likely if you remove the stock pressure switch, the O/P light will never come on, it only turns on when the switch closes and completes the circuit for the light. If you want both the gauge and light to work, you can either install the new sender someplace else, or add a tee-fitting to allow both senders to be installed or get a dual output sender with both gauge and light outputs. I did this on my VW diesel, unscrewed the old switch and screwed in the new sender and both the light and gauge work:
http://egauges.com/vdo_sgrp.asp?Subg...ressure_Sender
bigjstang
08-25-2021 12:41 AM
06-01-2021 01:51 PM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
coryc85
09-09-2015 06:24 AM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: installing oil pressure guage, will the light stay on?
