91 3vze compared to 94 3vze
Old Dec 30, 2007 | 11:32 AM
91yota3.0's Avatar
i have a 91 toyota v6, the engine blew head gasket, so i just bought a 3vze from a 94 toyota 4x4 auto, i was looking at the engines and noticed the 94 block doesnt have the oil cooler on it, it just has some kind of cover where the oil cooler would be, does anyone know what the differences are between the two engines
Old Dec 30, 2007 | 11:37 AM
DeathCougar's Avatar
is the new engine 4wd the same as yours? (or 2wd, whichever it is)
The fan support is different as well. In 93 they switched to a hydraulic timing belt tensioner, thus requiring different heads and front fan support.
Of course the wiring harness and other subtle things will be different.
Old Dec 30, 2007 | 11:51 AM
toytech76's Avatar
Eng is the same, you will just hafta remember if you or anyone else is doing a tbelt to remember what year the motor is since it will take a different belt
Old Dec 30, 2007 | 11:54 AM
toytech76's Avatar
oh yah...I think the knock sensor will be the newer style so your eng harness won't plug into it. You can however take the sensor from your old eng and install it into your new one. I myself would buy a new one even tho they are spendy. Everytime I rebuild one of these I recommend replacing them because it never fails that you get it all back together and after 2 days you end up getting a code 71 (knock sensor). Insurance against having to tear the intake off again
Old Dec 30, 2007 | 12:50 PM
91yota3.0's Avatar
alright does it matter that the 94 engine doesnt have the oil cooler on the side of the block, but the 91 did
Old Dec 30, 2007 | 02:03 PM
toytech76's Avatar
No because the oil cooler has one coolant line to the block and one to the waterpump. Just remember that if you ever hafta replace the w/p. Some come with the nipples and some without
Old Dec 30, 2007 | 08:28 PM
stormin94's Avatar
They should be pretty much a carbon copy of oneanother.
Old Dec 30, 2007 | 08:44 PM
eh nope
And you can just switch the oil cooler from your 91 to the 94, you will just need the correct water pump. I would suggest it since it sounds like you have a 4x4, and the engine came from a 2WD
Old Dec 30, 2007 | 08:51 PM
91yota3.0's Avatar
yea my 91 toyota is a 4x4 and the motor i bought was in a 94 ext cab sr5 4x4
Old Dec 31, 2007 | 06:24 AM
runethechamp's Avatar
There is an oil cooler on the block of my 94 4runner.
Old Dec 31, 2007 | 07:31 AM
Yoda's Avatar
For what it's worth, I would change the timing belt and WP before installing the engine (unless you have documentation it was done)
We swapped a 95 engine into a 91 truck. Same issues. We did the belt, WP, and swapped the oil cooler.
Old Dec 31, 2007 | 12:49 PM
bigtrucknwheels's Avatar
what neck of the woods are you from? Im trying to hunt down an SR5 interior from an Xtra cab... Also looking for a 5 speed if the truck had it. I'd buy it whole...
Thanks, in advance, for the reply.
Old Jan 1, 2008 | 07:18 PM
91yota3.0's Avatar
the knock sensors are located under the intake manifold, and screw into the block right? think my service manual says there are 2 knock sensors on the 3vze
Old Jan 1, 2008 | 07:55 PM
toytech76's Avatar
Yes thats where it is. No...3vz only has 1 knock sensor. There are 2 different styles. The early and the late style. The connector is the only difference. You ALWAYS replace the wire between the sensor and eng harness anytime you hafta pull the manifold off. Cheap insurance
toytech76's Avatar
the 3.4 5vz has 2 sensors
Old Jan 1, 2008 | 08:55 PM
91yota3.0's Avatar
alright thanks for the help
Old Jan 1, 2008 | 10:07 PM
toytech76's Avatar
NP! Just ask if ya need anything else
Old Jan 1, 2008 | 10:24 PM
Is this YOU?
http://seattle.craigslist.org/est/pts/525636708.html
do I smell a 3.4L swap?
Old Jan 2, 2008 | 04:09 PM
91yota3.0's Avatar
yea thats my motor, was going to put that in my truck for now just to get it running, but changed my mine, want the 3.4 swap have done a ton of reading about it, now thats the route im going to go.
Old Jan 2, 2008 | 06:22 PM
Very nice! Keep us updated
MadMax48
Mar 3, 2020 10:33 AM
Kamaloha
Oct 16, 2015 05:13 PM
alexcarey
Oct 14, 2015 06:05 PM
Matthew Perez
Sep 28, 2015 05:43 PM
charlie_fong
Sep 27, 2015 10:06 PM
