Truck starter problem??
Old Jan 2, 2008 | 06:30 PM
eightnine's Avatar
I was just at my buddies house, and it was really cold outside like -20C and the truck took longer than usual to start.. it usually starts on a dime but this time it took maybe 2-3 seconds longer. Then after I turned it off to put some more oil in the motor, I tried to start it and it would even make a sound. I then held the key on the start position and it started to try to crank, eventually starting (6-7seconds of cranking). I just got home and after turning it off i started it again 3-4 times and it started in a little longer than usual like 4-5 seconds longer. Any ideas what it could be?
Old Jan 2, 2008 | 06:44 PM
CJM's Avatar
CJM
Your battery is weak..
Old Jan 2, 2008 | 06:47 PM
toytech76's Avatar
Sounds like your starter contacts might be getting worn. If you held the key in start position without it cranking, your cold start injector is pumping gas into eng resulting in a longer crank time when it does turn over because its slightly flooded.
eightnine's Avatar
But all the lights were working fine and i didnt even notice them being dimmer?
Old Jan 2, 2008 | 06:49 PM
CJM's Avatar
CJM
My work van does it to when its cold outside. The contacts could be getting worn as well, always possible.
Old Jan 2, 2008 | 06:51 PM
eightnine's Avatar
If the lights are one fine, would that disqualify the battery completley? I guess im just trying to hope its the battery instead of the starter. The battery is rele old 8 years+ btw
Old Jan 2, 2008 | 07:04 PM
toytech76's Avatar
You can have lights and still have a bad batt. If you experience a rapid clicking sound when the truck doesnt start then its probably your battery. Other than that I would susp your starter contacts or a bad connection somewhere
Old Jan 2, 2008 | 07:06 PM
eightnine's Avatar
If it only occurs when it is really cold, would it disqualify the starter?
Old Jan 2, 2008 | 07:09 PM
toytech76's Avatar
no. extreme cold and heat will create more resistance. If your battery is 8 yrs old you should replace it anyways just so you dont get stranded. See how that works and if you still have a problem go from there. Possibly check your starter
Old Jan 3, 2008 | 11:43 AM
eightnine's Avatar
I just went out again to start it and this time all the lights dimmed a lot and then lit up while i started to crank it. It did crank after a few seconds tho? Is this sounding like a crap battery? Im gona get it changed anyway
BTW thanks for all the quick responses
Old Jan 3, 2008 | 11:47 AM
CJM's Avatar
CJM
Yep, sounds like a bad battery. Check the terminal connections on the battery too and see if they are all nasty and clean them, then see if it helps. If it wasnt a bad connection its a bad battery. If you havent replaced it in about 3-5 years its time.
voiddweller
19
May 2, 2016 09:10 PM
bigblue82
10
Jul 6, 2015 08:27 AM
Crazy_Guy97
12
Jun 24, 2015 04:02 PM
Toyota Punk
Jul 1, 2002 05:44 PM
