whine
Old Jan 2, 2008 | 11:26 AM
87turbo's Avatar
whine
So i have a whine that sounds kind of like i have a gear drive set up but not quite that loud. It only makes the noise when i am accelerating which makes me think its not the motor but more of a drivetrain sound, it doesnt really get louder with rpm either its pretty steady. Also it is coming from the front end area not the rear. Any ideas?
86 pickup, 5spd, 22re freshly rebuilt, 220,000 miles on most of the drivetrain.
Old Jan 2, 2008 | 11:31 AM
swaycleveland's Avatar
ive got a similar whine coming from the front of my 93 runner only on acc never when the gas is off i found a thread about a whine TC had and a fix im gonna try it soon but if you find out let me know the thread is something about the front shaft being dry and theres evena way to fix it look up TC threads
Old Jan 2, 2008 | 11:35 AM
just found the thread its called "Horrible sound when hubs locked " search that it sounds like what i have maybe its the same !
Old Jan 2, 2008 | 11:55 AM
run4her's Avatar
Does it have a bunch more power maybe someone put in a supercharger when you were sleeping? lol
Old Jan 2, 2008 | 01:24 PM
87turbo's Avatar
hahahaha i wish.
Old Jan 2, 2008 | 02:41 PM
isaac338's Avatar
are you driving your turbo when you hear this whine? keke
Old Jan 2, 2008 | 03:16 PM
Flash319's Avatar
Transmission input bearing is going. Does it change or get quieter in 4th gear? If so then that is it. If you fix it now you may be able to save the trans, if you don't it will start popping out of gear and then bye bye.
Old Jan 2, 2008 | 03:26 PM
Targetnut's Avatar
drive it til it blows then look for the broken parts.
Old Jan 4, 2008 | 10:49 AM
87turbo's Avatar
turned out to be power steering pump, i threw in some lucas sealer and condition and no more whine.
Old Jan 30, 2008 | 08:00 PM
fire5's Avatar
Where did you add the sealer. I have a squeal at start up followed by constant whine or whirring. Listened around with a stethoscope and the whirring is loudest at the power steering pump.
Old Jan 31, 2008 | 07:18 AM
nate V's Avatar
adding 80-90 works too
I8URSVT
Jan 15, 2016 07:25 PM
Higbee89
Aug 27, 2015 06:52 AM
norcal98
Aug 10, 2015 06:20 AM
Jonny246
Jul 24, 2015 12:37 PM
mengquis
Jul 13, 2015 10:39 AM
