oil cooler
Old Dec 30, 2007 | 01:23 PM
rogertoy's Avatar
oil cooler
I have a 94 4runner that spun a bearing. I have located what appears to be an oil cooler on right hand side of block . Can this part be cleaned or does it have to be replaced. I am afraid metal shavings might have gotten into this part. Can anyone help?
Old Dec 30, 2007 | 01:27 PM
MMA_Alex's Avatar
which engine is this? you should be able to flush it out with oil if you're concerned.
Old Dec 30, 2007 | 01:32 PM
rogertoy's Avatar
eng is 3vze
Old Dec 30, 2007 | 01:37 PM
rogertoy's Avatar
eng is 3vze
Old Dec 30, 2007 | 01:52 PM
toytech76's Avatar
yes you can clean it out. It would work best if you had a solvent tank but if you don't then you can run carb cleaner or smething of the sort through both ends. Run alot through and blow it out well with air
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
this_guy
Jul 31, 2015 01:27 PM
calderp
Jul 27, 2015 09:58 AM
Coreyr384
Jul 10, 2015 11:13 AM
Snort
Jul 9, 2015 03:58 PM
