hard to shift into 4-Hi ?
Old Jan 3, 2008 | 05:12 AM
highway's Avatar
EDIT: truck is a 1989-4cyl-manual hubs
Got some snow last night and i locked in my manual hubs and after i had gone about a mile i needed to shift into 4-hi. When i pulled back on the shifter it would just grind and not engage, after coming to a complete stop it did finally engage but was hard to go in. so after a bit i took it out of 4-hi to see if it would work again and no go only when i stopped. so engaged it into 4-hi again and die-engaged on the fly and i could hear a awful whining noise that wasn't there before (sorta sounds like a gear that was not fully engaged) so i quickly pulled it back into 4-hi and the noise stopped and the 4x4 stared to work perfect....any ideas ? could it have been due to the cold temperatures? it was 18 degrees when i pulled out.
highway
Old Jan 3, 2008 | 05:43 AM
pat24's Avatar
did you try shifting into neutral try that and see if that will shift better thats why i do on a personal note i beilve it is better for the t case and tranmision
i hope you get it figured it out
Old Jan 3, 2008 | 06:19 AM
highway's Avatar
yeah tried with the tranny in neutral....same results grind sound
Old Jan 3, 2008 | 07:38 AM
MMA_Alex's Avatar
check the gear oil level in the t-case. If it's low it'll have trouble shifting
Old Jan 3, 2008 | 08:33 AM
highway's Avatar
I went out this morning and tried and it worked perfect 4hi and 4lo, hope it was just the cold
highway
Old Jan 3, 2008 | 09:00 AM
MMA_Alex's Avatar
highway
it could very well be. synthetic will work better at low temps. It's still worth checking the level.
Liadrin
Apr 25, 2022 02:54 PM
rusty904
Mar 27, 2017 05:20 PM
Liadrin
Sep 1, 2015 06:44 AM
JAmdor3
Aug 11, 2015 10:53 AM
crashburnoveride
Jul 10, 2015 06:39 AM
