Engine Switched Now No Spark
Old Dec 31, 2007 | 12:26 PM
Millertime's Avatar
Question Engine Switched Now No Spark
I just replaced my 94 v6 w/ a rebuilt 92 v6 and switched over the bolt ons including distributer. I have everything hooked up and went to start and there is no spark . It turns over fine and has fuel, any suggestions? One other thing it does have an after market alarm, can this be the cause of no spark? I thought alarms kill the motor at the starter?
Old Dec 31, 2007 | 05:55 PM
Georgiadave's Avatar
Something in the ignition system is not installed properly. The distributor is a prime suspect. Read other threads on how to set a misaligned distributor to TDC. Other potential causes include no distributor rotor, loose coil wire, coil not connected correctly, faulty cap, you name it.
Old Jan 1, 2008 | 06:18 AM
Millertime's Avatar
is it possible that the knock sensor can cause no spark if hooked up incorrectly? the motor is a 92 and the plug on the 94 harness is different and I did not have the correct plug so I modified it.
Old Jan 1, 2008 | 10:14 AM
Millertime's Avatar
I have been checking the coil, distributer for resistance and all seems correct and I cant find any connections that I missed this really sucks. I get no spark out of coil wire when cranked, any other suggestions would be great
Old Jan 1, 2008 | 10:58 AM
toytech76's Avatar
A knock sensor will not cause a no start condition. Check all grounds. More than likely its something not hooked up or hooked up wrong since this happend after a motor swap. Recheck your work
Charecter1
Nov 6, 2023 10:08 AM
smiley52
Jul 11, 2015 05:16 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
skoti89
Jul 8, 2015 12:05 AM
colinmil
Jul 6, 2015 04:03 PM
