Anybody on who can help with a quick ball joint spacer ?
Old Feb 19, 2012 | 08:56 AM
DetroitStyle's Avatar
I'm in the garage found SDORI ball joint spacers up front... And trying to remove the stock bolts... It appears that the heads are round? I've trying lightly just banging the bolts out... But don't want to screw anything up.... Are the stock bolts threaded up in there? Or just pressed in? Keep banging?
Old Feb 19, 2012 | 09:10 AM
skoti89's Avatar
im sorry. explain a little more. your trying to remove your upper ball joints to install the spacers?
it may be the beer, but for some reason I dont under stand what your saying.lol
Old Feb 19, 2012 | 09:12 AM
BLKNBLU's Avatar
I'm not quite following your post. Are you trying to install BJ spacers? And you have the new hardware to put the spacers in with? And you're just trying to get the old bolts out of the current ball joints in order to re-use them?
If yes to all of that, then yes, bang away. Just be careful to not hit the BJ boot or stem. Some BJ's come with nuts and bolts but many come with nuts and pressed in studs. That is how mine were and sounds like yours too. Just support the base on something solid with a void for the stud to fall into. A deep socket or slightly open vice works well.
Good luck.
Old Feb 19, 2012 | 09:17 AM
BLKNBLU's Avatar
After re-reading your post, I'm thinking you already have BJ spacers. If so, those round heads are allen bolts and not pressed or threaded. If they are not sliding out it is probably due to crud and/or corrosion. In that case, penetrating oil, time, and a light touch are your friends.
Old Feb 19, 2012 | 09:19 AM
xxxtreme22r's Avatar
Nut and/or 2 nuts one being lock nut on top and the lower I believe is an allen head.
Those bolts go all the way though.
Old Feb 19, 2012 | 09:40 AM
Sorry my first post wasn't clear... was typing from my phone... stupid autocorrect was changing words.
I am in the process of installing the SDORI ball joint spacers up front and cannot seem to get the stock bolts out. My local mechanic tells me that they are pressed in. Is that true?
Old Feb 19, 2012 | 09:45 AM
Old Feb 19, 2012 | 09:50 AM
Instructions: http://www.4crawler.com/4x4/ForSale/...owTo.shtml#4WD
Old Feb 19, 2012 | 10:02 AM
topdog63's Avatar
Yes those studs are pressed into the ball joint it's self. It's kinda like a wheel stud. You have to pound them out. If you want to save the threads on those studs, put the nuts back on there so that it covers the end threads so they don't get boogered up from whacking them with a hammer. Good luck. It shouldn't be too hard. I might suggest that since you already have the ball joints mostly out, go get some new ones to put in then you don't have to worry about it for a while. Also, if this is a driver and not just a wheeler, go get an alignment. The $50 alignment will save you hundreds in tires down the road.
Old Feb 19, 2012 | 10:03 AM
Originally Posted by xxxtreme22r
I have that printed out here with me. All it says is "remove the ball joint hardware" and "Press out the studs with a small hammer"
My stock studs sure look like they are threaded all the way down, but the head of the studs is pretty much round. I pretty much to the point now where I know if I hit them any hard, it's going to start bending and fusing stuff together... looks like I'm buying new balljoints.
Old Feb 19, 2012 | 10:09 AM
topdog63's Avatar
Probably best. It will save you from having to replace them again very soon. Make sure you get some that you can grease.
Old Feb 19, 2012 | 10:31 AM
BLKNBLU's Avatar
New ones may still have those studs in them and they will still need to be dealt with. If you can pop out your current ones in one piece you can get a better approach at those studs. If you want to try to save them you will probably do better with the screw down type of puller rather than a pickle fork. When I did mine way back when, I used a pickle fork as I planned on replacing them anyway, but then as I was removing them I figured they looked in pretty good shape and if I could get them out in one piece they might make decent spares. The pickle fork tore up the boots though and that was that.
Old Feb 19, 2012 | 10:41 AM
yeah, we just used the fork and it tore the boot and, as far as I can tell, destroyed the ball too. No choice now, calling around.
Thanks for the assistance guys... hopefully the re-install goes smoother. I swear, I'm never buying a rusty Michigan truck again
Old Feb 19, 2012 | 12:46 PM
OK, calling it quits for the day. I thought the front would be easier than the rear (LC coils!). Picking up new ball joints tomorrow morning and back at it. Hopefully re-assembly should be easy now that everything it removed, cut, notched, clean, etc... just slap 'em together and bolt it up!
Old Feb 20, 2012 | 12:01 PM
Well... just a quick update. This morning STARTED with a pleasant surprise, which was that my MOOG ball joints DID NOT come with the bolts pressed in! Sweet! one less headache.
Driver's side went great. Passenger side = stock ball joint stud is completely frozen in there. I had to give up for the day... but here it is with the driver's side done and on the ground.
and yeah, I think it's just an optical illusion in the garage... I don't think the front is really higher than the rear... because when we were done with JUST the rear LC coils... it looked level inside the garage and jacked in the back when it was outside. It's something about the garage that makes the front look higher.
Old Feb 22, 2012 | 04:05 PM
and she's done
Old Feb 22, 2012 | 06:40 PM
Utah4Runner86's Avatar
Looks good. Did you check for rubbing on the upper a-arm? It's pretty common for the arm to rub on the sidewall, especially at droop.
Old Feb 27, 2012 | 06:56 PM
Here it is outside... Thanks for the help yotatech!
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
4x4YOTA
Aug 23, 2016 09:08 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
crash813
Sep 27, 2015 07:15 AM
