4cyl Rearends 2vrs4
Old Feb 27, 2012 | 02:53 PM
BajaToy616's Avatar
4cyl Rearends 2vrs4
Quick question I built up my 92 2wd 22re and ive been having a good amount of fun but i keep blowing the spider gears out of my rearends ive been through 3 5 lug 2wd 4cyl rearends is there a difference between the 4wd rearends for the 4cyl or do i need jusy to build a better rear end Are the 4wd rear ends stronger than the 2wd
Old Feb 27, 2012 | 02:59 PM
James Woods's Avatar
Most of the 2wd rear diffs are the 7.5, the 4wd 4cyl come with the 8 inch rear diff, the V6 and turbo rear diffs are even stronger. Some 2wd had the 8 inch as I have heard.
Old Feb 27, 2012 | 03:16 PM
BajaToy616's Avatar
i can only use a 4cly rearend i dont wanna swap my housing
o ill try a 4wd one this trip
Old Feb 27, 2012 | 03:27 PM
The V6 third member can replace a 4cyl one with no mods done, I am not sure if you can drop either 4x4 diff into the the rear of yours though because the spline counts might be different.
Old Feb 27, 2012 | 03:38 PM
BajaToy616's Avatar
they should be both 30s
SoCal_Todd
Oct 29, 2015 05:52 PM
Regency
Sep 24, 2015 07:23 PM
an1mal_69
Sep 8, 2015 09:40 AM
bobpat
Sep 1, 2015 07:25 AM
