fuel pressure regulator ?
Old Feb 28, 2012 | 07:50 AM
oldblue's Avatar
i pulled the vacuum line off of the feul pressure regulator and fuel came out, a good bit actually. I'm assuming this means the regulator is busted and needs to be replaced?
Old Feb 28, 2012 | 10:12 AM
BajaToy616's Avatar
Yeah thats not what is supposed to happen it means the diaphram is broken i have a couple on ebay though reasonably cheap if you need one or are interested.....btw i have never owned a 3.0 only the 22r and 22re are they any good
Old Feb 28, 2012 | 11:50 AM
scope103's Avatar
While I can't imagine you made this mistake, remember that the vacuum line is the smaller-diameter line "farther" from the fuel rail. The fuel return line (which is supposed to be full of fuel) is the other rubber hose.
Old Feb 28, 2012 | 12:44 PM
Crazy Hakachukai's Avatar
If you do have significant fuel in the vacuum lines, you might want to consider checking / cleaning out the rest of the vacuum system. It could still have fuel in it which is bad enough for obvious reasons... but additionally will degrade any non-fuel rated plastic parts that it comes in contact with.
That... just doesn't sound fun... at ALL!
jbv808
Aug 6, 2021 04:47 PM
Doug4320
Mar 24, 2018 10:11 PM
Poppie51
Jul 23, 2015 05:03 PM
v_man
Jul 23, 2015 04:01 PM
Poppie51
Jul 16, 2015 06:16 PM
