22r rebuild crankshaft seizing
Old Feb 21, 2012 | 05:14 PM
chevyoto's Avatar
i have a 22r that I am rebuilding and after putting the crankshaft I tightened the main bearing and thrush bearings and it was a little difficult to turn the crankshaft but it still turned. After putting the pistons in and torqued down the rod bearings and now the crankshaft is seized up. The entire time we have been putting oil on the parts but it is just regular motor oil and it was from the engine so it was used previously. I have never encountered this before and I am hoping someone else has and can help me out.
Old Feb 21, 2012 | 06:09 PM
James Woods's Avatar
Did you make sure to put the main and rod caps back in the proper order as in numbering which cylinder they belonged to before taking it apart?
Old Feb 21, 2012 | 08:08 PM
PowerstrokeJoe's Avatar
Did you use plasitgauge to check the clearance on all of the bearings. It is not really an exact thing but it will give you an idea. I just finished rebuilding the engine in my truck and the first set of bearings I got were oversized but in a standard package. You might mic the crank too. You need to make sure that all bearing caps are on the right direction and in order as well as making sure the pistons are in the same jugs.
Old Feb 21, 2012 | 08:52 PM
chevyoto's Avatar
Didn't use plastiguage, but I did mic the crank, main and rod caps were numbered. I did just pull everything out and put it in another block and molly lube. It is turning a little more freely now but it still needs a wrench to turn and not by hand.
Old Feb 21, 2012 | 08:58 PM
Try using some plastigauge to see where you are at, but if you put everything into another block, you may need to get it line bored.
Old Feb 21, 2012 | 10:04 PM
Grego92's Avatar
In addition to what the previous guys have said as far as checking everything, if it makes you feel any better I had the same issue and asked on this board also. A couple guys (edit: seemed to agree) it was probably the new hardware and to try turning with the help of a socket wrench....which I could so I kept going with my build. Unfortunately I'm not done so can't tell you any more than that.
Before I took it apart I could turn it by hand. Then I had my crank checked and ground down .010, new oem taiho rod/main/thrusts bearings to match, block checked and honed cylinder walls, and new npr pistons/rings. I did green plasti-guage all bearings and had proper readings and used clevite assembly lube. After assembly I could only turn by a 1/2" socket but didn't use much muscle though. I'm pretty confident it's fine and I'm being a little paranoid with my first full rebuild.
Old Feb 23, 2012 | 02:01 PM
chevyoto's Avatar
I got everything back in and guess what? The timing chain was put on while the first piston was down. Does anyone have any tricks to moving the timing chain without taking the timing cover off.
cars-guy
Aug 16, 2020 06:59 AM
young buck
18
Aug 27, 2018 02:40 PM
dumpster84
Apr 30, 2016 06:03 AM
Jcrawl94
10
Oct 24, 2015 04:34 PM
Nickyodaman
Jul 27, 2015 12:13 AM
