replaced starter on 90 22re,still no start
Old Feb 29, 2012 | 01:40 PM
brino1's Avatar
ill start at the beginning.was having troubles with starting,usually a couple taps to the starter and it would fire up.last couple times i tried to start id have to run back and forth a couple times tapping the started.when it would start the starter wouldnt disengage for 3 or 4 seconds after starting.so i replaced the starter today.im getting the click behind the dash.but no start.the starter spun a couple times but didnt engage and didnt spin every turn of the key.any ideas???
Old Feb 29, 2012 | 04:41 PM
brino1's Avatar
anyone??
Old Feb 29, 2012 | 06:30 PM
brino1's Avatar
just went out and messed with it some more.it spun every time i turned the key but it didnt engage.the starter did stop spinning when i backed the key off though.any ideas at all?
Old Feb 29, 2012 | 09:37 PM
v8sport4runner's Avatar
I would check the positive lead from battery to starter. If it has a bad contact, corrosion or cracked insulation maybe its not passing enough juice to pop the gear out.
Old Feb 29, 2012 | 09:48 PM
Also, did you put a whole new starter in or rebuild the old one? Maybe you got a bum starter since it spins but doesnt engage. The old one probably just had worn out contacts in the solenoid and perhaps the plunger was sticking in the out position. They are cheap and easy to rebuild, so dont chuck it. Replace contacts, clean up the plunger and sell. Or better yet put it back in. The stock one is of better quality than an inexpensive autoparts store starter.
http://www.4crawler.com/4x4/CheapTricks/Starter.shtml
Old Feb 29, 2012 | 10:31 PM
wyoming9's Avatar
Red face
Sounds like a bad starter drive.
the quality of re manned starters has gotten so bad as of late
Then you have new ones made in china that are not much better if not worse.
Then again unless you inspected the ring gear you might have missing teeth that could also cause the same problem of the starter just spinning with out engaging
Old Mar 7, 2012 | 06:11 AM
brino1's Avatar
it was the wrong starter.bolted up and had the same connections.but the selenoid didnt run out far enough to meet the flywheel
Old Oct 12, 2012 | 12:19 PM
yprior's Avatar
Wow, where did you get that starter, so I never go there.
voiddweller
19
May 2, 2016 09:10 PM
Ichneumon
Sep 27, 2015 04:21 PM
bigblue82
10
Jul 6, 2015 08:27 AM
Old Red 94
Jun 16, 2015 08:32 PM
Toyota Punk
Jul 1, 2002 05:44 PM
