Gearshift will not move when on. Only when off?
Old Feb 13, 2012 | 05:11 PM
Tonythehelmet's Avatar
I have an 87 4x4 22r 5 speed. When engine is on the shift will not move. When off it seems to shift easily. Why?
Old Feb 13, 2012 | 05:15 PM
justin_4runner's Avatar
see if u have clutch pedal, is the fork moving in and out? i would say u dont have pressure for the clutch... if it is moving then i would be looking at the synchronizes are bad.
Old Feb 13, 2012 | 05:19 PM
Could it be a slave cylander prob? My friend suggested it.
Old Feb 13, 2012 | 05:22 PM
Wow what a poor speller I am. Could it be clutch related?
Old Feb 14, 2012 | 10:46 AM
abecedarian's Avatar
If you can run the lever through all 6 positions- 1,2,3,4,5 and Reverse, with the engine off but can't get it into any gear with the engine running and the clutch pressed, yeah, it could be the clutch not disengaging when you press the pedal down.
Like mentioned, check that the release fork moves when the clutch pedal is pressed. If it doesn't, check that you have fluid in the clutch master cylinder- it's a small reservoir next to the brake booster. You can use DOT3/4 fluid to fill it and there's a bleed screw on the clutch slave cylinder, which is bolted to the side of the transmission.
Old Feb 17, 2012 | 10:21 PM
jkepoo's Avatar
Could be clutch bracket had that prob with my rig
Liadrin
Apr 25, 2022 02:54 PM
raptor510
Feb 17, 2017 07:11 AM
skoob
Oct 15, 2015 03:23 PM
CanRunner
Jul 20, 2015 01:29 PM
rushw
Jul 18, 2015 01:46 PM
