Throttle sticking!!!! DANGEROUS!
Old Feb 28, 2012 | 12:17 PM
woodyth's Avatar
Throttle has been sticking lately and I am assuming it's the cable binding. Anyone ever had this happen to them? Where do I get a new cable from? been looking for a new one for about 3 hours now online and cannot find one! Anything else it could be?
Thanks
Woody
Old Feb 28, 2012 | 12:39 PM
Crazy Hakachukai's Avatar
Does it stick every time, or only at random times?
If you disconnect the throttle cable from the linkage and operate it by hand, does it also stick?
Old Feb 28, 2012 | 01:21 PM
woodyth's Avatar
Just was going to try to lube the cable itself when I came upon this, my linkage in my weber seems to be what is sticking I think. Here's the video:
http://youtu.be/MIxCDSsPkJg
What do I do now?
Last edited by woodyth; Feb 28, 2012 at 01:36 PM. Reason: trying to get video to work
Old Feb 28, 2012 | 01:28 PM
Either the link is broken, or something is up with my browser. If you post a normal straight link that I can put into my web browser I'll take a look.
Old Feb 28, 2012 | 01:36 PM
woodyth's Avatar
there fixed lol
Old Feb 28, 2012 | 01:54 PM
It's really hard to tell from that video, but it sounds like something is scraping, and then hanging.
Do you see any scratch marks where metal has been rubbing on metal?
Old Feb 28, 2012 | 02:22 PM
woodyth's Avatar
not as far as I can see. one thing I thought of was the nut that you install the link to the throttle cable with i guess has a tendency to tighten itself so going to try loosining that nut some and see what happens, got a email into weber direct also.
Old Feb 28, 2012 | 02:28 PM
How old is that Webber?
I just happen to have one sitting around. I'll bring it in and take some pics to see where it could possibly be binding up
Old Feb 28, 2012 | 02:45 PM
woodyth's Avatar
4 months old.
Old Feb 28, 2012 | 03:04 PM
http://www.warp-central.com/crazy_ha...ebber_jam1.jpg
http://www.warp-central.com/crazy_ha...ebber_jam2.jpg
Check the areas circled in red for binding.
I noticed that when I simulated a stuck 2nd barrel, that it acted like, and sounded like your Webber in the video
Old Feb 28, 2012 | 05:06 PM
It seems to me like the accelerator pump slide arm is jamming. I'd check there first. That is the red circle in the 2nd pic above
Old Feb 29, 2012 | 12:07 AM
woodyth's Avatar
thank I think I will check it out tommrow
Old Feb 29, 2012 | 12:25 AM
goodyota's Avatar
i had the same problem with my webber! all i did was go to the parts store and get a return spring. i hooked one side to the linkage and the other to the bottom lip of the filter housing and it worked great. hope it helped
Old Feb 29, 2012 | 02:38 AM
I'd hit those areas with a little wd40.
If that immediately solves the issue, then I would add a bigger return spring like Goodyota said.
If it doesn't solve the issue, then it must be hanging up somewhere else.
Old Feb 29, 2012 | 02:50 PM
woodyth's Avatar
hit those areas and guess what..........it worked! thanks for the help!!!!111!
pickle6415
Apr 14, 2021 06:20 AM
Shaun Crystal Gomban
Sep 20, 2015 11:16 PM
80Truck
Sep 15, 2015 04:21 PM
yoterr
Sep 15, 2015 06:26 AM
theduck21
Sep 10, 2015 07:01 PM
