Pro comp coils?
Old Feb 19, 2012 | 06:10 PM
FuelforWar's Avatar
Pro comp coils?
So I installed some pro comp coils with 4in of lift this prior summer. they seem to have done well, but i've noticed a sag on my passenger side steadily getting worse. Now the passenger side is sitting 2-3in lower than the drivers side. Is this due to an incorrect panhard bar or have I just make a bad purchase on these. Input heavily appreciated.
Old Feb 19, 2012 | 09:39 PM
FuelforWar's Avatar
....any info? is there anything other than the coil that will make this side sag so badly? there only a few months old.
Old Feb 21, 2012 | 02:38 PM
FuelforWar's Avatar
Well I swung by 4wheelparts today (where i bought the coils), They called procomp and there still under warrenty so I'll have a replacement set this friday. Hope this fixes the issue.
Old Feb 21, 2012 | 03:09 PM
Levinz11's Avatar
You will def. need to drop the panhard bar with that much lift.....if you didn't the first time. Is the passenger side wheel sticking way out?
Old Feb 21, 2012 | 04:18 PM
FuelforWar's Avatar
Panhard bar is installed. But i'm not sure if its too long. i was told this shortly after installing them last time. Was told to measure from ground to bolt on both and the difference was the size I needed. Well I have 7" of difference, so i bought a 6" panhard drop bar. well now with that side of the truck sagging, its not level anymore. Should have I only gone with a 4" drop since my coils were 4+ over stock?
justdifferentials
14
Jun 11, 2017 08:36 PM
voiddweller
Oct 2, 2015 07:47 AM
the_supernerd
Oct 1, 2015 09:20 PM
myotherrideisayoshi
Sep 29, 2015 05:41 AM
Odin
Sep 26, 2015 06:56 PM
