22re rough idle and acceleration after TPS changed
Old Feb 23, 2012 | 12:57 PM
BHUDDA's Avatar
Hey guys! I'm new to the site here and I have a little bit of a dilemma. I have a 1992 pickup with 74,000 (yes you read that right 74K) on the odometer and for the past few weeks it started to idle rough and sounded like it was going to die but never would. I fiddled with it a bunch and changed some parts but finally I had to take it to a local shop and put it on a computer and they said they thought it might be the throttle position sensor. So they unplugged it and she ran just fine. Once I finally got a TPS in it the next day it started to act up again. My thought it has something to do with the air intake? I was hoping someone on here might of had the same problem or has some advice. Thanks in advance for all the Help!
Heres a pic of my truck just case I'm new haha.
Attached Thumbnails 22re rough idle and acceleration after TPS changed-photo-6.jpg
Old Feb 23, 2012 | 01:28 PM
bttrs's Avatar
there is a couple of things that would/could cause your problem. i myself have dealt with similar problems a lot. first thing to do, pull your MAF and ohm test it.
http://www.4crawler.com/4x4/CheapTricks/AFM/index.shtml
if that ohms out okay i would use the jumper wire to see that your fuel pump is running good, check your circut open relay to. i would be willing to bet the info you need to fix your truck is in that link if none of that works, search through that site there is a TON of great tech and info you wont find anywhere else. good luck
Old Feb 23, 2012 | 01:34 PM
BMcEL's Avatar
Did you adjust the TPS or just slap it in there?
Old Feb 23, 2012 | 01:41 PM
BHUDDA's Avatar
Yes I did adjust it.
Old Feb 23, 2012 | 02:48 PM
XtraSlow_XtraCab's Avatar
Did you adjust it via the "book procedure"? Ohmmeter, feeler gauges, etc?
Old Feb 23, 2012 | 02:54 PM
BMcEL's Avatar
The TPS can be a pain to adjust properly. If it still runs better with it unplugged, chances are it's out of adjustment.
smthwsn357
May 1, 2024 07:28 AM
Eggslinger
Jun 8, 2019 03:32 PM
Sep 4, 2015 09:27 AM
smiley52
Jul 11, 2015 05:16 AM
88runnergomas
Jul 9, 2015 01:12 PM
