rear main seal leaks
Old Feb 23, 2012 | 08:06 AM
macdaddy69's Avatar
Arrow rear main seal leaks
I have a 93 4 runner that the rear main seal is leaking. cant i just pull the tranny and transfer case out to get to the seal. If you have any tricks let me know. Thanks
Old Feb 23, 2012 | 08:24 AM
irab88's Avatar
yes.
https://www.yotatech.com/forums/f116...thread-246983/
/thread
Old Feb 23, 2012 | 08:47 AM
BMcEL's Avatar
Before you go pulling the transmission, are you certain it's not the valve covers leaking?
Old Feb 23, 2012 | 09:39 AM
macdaddy69's Avatar
Thank you
Old Feb 23, 2012 | 09:44 AM
macdaddy69's Avatar
I checked the valve cover gaskets and they are not leaking. I just got done with replaceing the oil cooler o rings that where leaking. I was hopeing it was residual oil from that but it isnt. Thank you
Old Feb 23, 2012 | 08:32 PM
scope103's Avatar
Excellent advice.
Gravity is not your friend; EVERY oil leak will look like a main seal within a few seconds. I assume the OP cleaned his rig very carefully, and then looked for the leak.
Old Feb 24, 2012 | 04:23 AM
waskillywabbit's Avatar
I'd get an in person 2nd opinion from an independent unbiased mechanic before I tore it all apart. I wouldn't mention your suspicions, don't influence him.
:wabbit2:
Old Feb 24, 2012 | 06:50 AM
macdaddy69's Avatar
ok thanks
Old Feb 24, 2012 | 06:55 AM
macdaddy69's Avatar
it is very clear that the rear main is leaking. i cleaned everything and laid there under my rig and watch the oil start leaking from behind the cover plate. thank you for your time
Old Sep 13, 2012 | 03:23 PM
SlightlyWhat's Avatar
couldn't find the thread I was posting in.
So I "redid" the rear main and I've had oil setting in there for a while...I didn't do it completely right apparently because well I'm still leaking some oil but now my truck is making a squeaking noise when it runs. It has oil in it but it's running really hot.
jerusry
Oct 19, 2015 05:28 PM
andrewtexas123
Jul 14, 2015 04:29 AM
jakebarrett
Jul 10, 2015 07:15 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
toyoda8488
Jul 5, 2015 10:18 PM
