front pinion bearing removal
Old Feb 19, 2012 | 02:09 PM
BLRobertson's Avatar
The front pinion bearing on the rear axle of my 94 4cly pickup doesn't seem to want to budge. The inner race doesn't give very much area to grab onto so I didn't think it should take alot to get it to move but this one is being very stubborn. Any ideas or helpful hints? Thanks
Old Feb 19, 2012 | 04:43 PM
MudHippy's Avatar
They're meant to be hammered out with a drift pin. That's the only way I've ever done it. Piece o' cake...
See page SA-140.
http://personal.utulsa.edu/~nathan-b...35differen.pdf
There's a couple of notches on both sides of the housing behind where the races sit. Put the drift pin in the notch and bang one time on each side back and forth to push it out evenly. You'll see what I'm talking about...
Old Feb 19, 2012 | 05:20 PM
As the manual describes in removal of the front bearing they use a SST09556-30010 to grab the inner race and pull the bearing out. That's where my problem starts. I've made a tool similar to the SST but it continues to slip off before the bearing moves. It's like the bearing is stuck to the pinion shat. Can that happen if the pinion nut has been overtightened?
Old Feb 19, 2012 | 06:57 PM
MudHippy's Avatar
Oh, I thought you meant the race. You mean the bearing. Well, that's obviously impossible, as you can tell. Hell, I wouldn't have even wasted my time trying it. There's other ways in can be done.
Hint: Remove the pinion from the bearing. Not the bearing from the pinion.
Like this for instance...
http://www.youtube.com/watch?v=tTMGu...41AHT0FiCAAbAA
Old Feb 20, 2012 | 04:03 AM
Thanks for the video, I guess a press might save a few hammers. That answers what should have been my original question. It sounded from other posts like people were replacing the bearing spacer or solid spacer without completely removing the pinion shaft. Anyway thanks again I'll bite the bullet and pull it all down.
Old Feb 20, 2012 | 04:29 AM
I'm a bit confused about the preload. FSM says to initially set the torque on the pinion by itself to 7.8-11.3 in/lbs for reused bearing. But it seems to have the same callout once the carrier is installed like during a seal replacement. Am I reading this correctly?
88sasturbotoy
Jan 30, 2026 01:57 PM
the1998sr5
15
Jul 14, 2020 08:35 PM
oldirtydirt
Feb 23, 2020 09:30 AM
jasonty
41
Dec 23, 2018 01:00 PM
Sep 4, 2015 09:27 AM
