thermostat
Old Oct 22, 2011 | 09:47 PM
trout's Avatar
thermostat
I went to change out my thermostat today and i could not get the nuts off is there a trick or should try to heat them up or what.... any help would be great
Old Oct 22, 2011 | 09:53 PM
BMcEL's Avatar
Hit them with your purse.
Old Oct 22, 2011 | 09:58 PM
wyoming9's Avatar
Smile
I tried that but my purse is way to big to be able to hit the thermostat housing
These bolts are known for breaking you can try soaking with your favorite
I would have a M8x1.25 thread replacement kit of your choice on hand along with new bolts.
Old Oct 22, 2011 | 10:15 PM
Mr.Utah's Avatar
nuts? I thought there are a couple of small bolts holding this on. It would help to know what year, motor, etc!!
Old Oct 22, 2011 | 11:03 PM
trout's Avatar
it is a 91 toyota 4 runer v6 3l
Old Oct 23, 2011 | 05:55 AM
MudHippy's Avatar
3 studs, 3 nuts. Which is good. Because you've got twice the chances of breaking them free. If the nuts won't budge, maybe the studs will(nut still attached)...eventually.
Penetrant soak + 6 point 12mm impact socket + breaker bar = your best chance of success.
As long as yours doesn't have the plastic t-stat housing, applying the heat wrench(torch) would be the last resort.
Good luck!
Old Oct 23, 2011 | 10:54 AM
vital22re's Avatar
totally a bro
Good luck!
X2. This is the way to go. Make sure you only use a 6 point socket. A 12 point will more than likely round the nuts.
kawazx636
Oct 6, 2021 03:03 PM
wberry85
May 17, 2016 05:45 PM
White Stripe
Oct 6, 2015 10:47 AM
rmill05
Sep 27, 2015 01:43 PM
LotOMiles
Sep 14, 2015 11:45 PM
