1993 4-nonrunner?!
Old Mar 26, 2008 | 08:04 PM
zookdogg's Avatar
1993 4-nonrunner?!
I recently purschased a 1993 4-runner with a 3.0 litre that isn't running right. It may run ok for an hour or maybe only a few minutes, but when it begins to run wrong it idles really rough, smokes black (as though it is running really rich), then dies. I have checked for codes in the computer but it isn't setting any. I was wondering if anyone else has had a problem similar to this or has any ideas?
Old Mar 26, 2008 | 08:25 PM
90inworks's Avatar
Valve not seating corectly at high temps?
Old Mar 27, 2008 | 03:34 PM
zookdogg's Avatar
Do you mean an intake or exhaust valve not seating properly once the engine is hot? If so, I don't think that is it because it runs goofy cold even sometimes. I was thinking maybe the afm is bad but I think maybe that would make it set some kind of code and maybe not be intermitant like it is. Anyone have a afm for this thing they wanna sell?
Old Mar 27, 2008 | 04:08 PM
zookdogg's Avatar
Anyone have any info on the cold start injector? I didn't know that these had such a thing. Could this possibly be the problem?
Old Mar 27, 2008 | 04:32 PM
SEAIRESCUE's Avatar
Its likely an electrical part such as a defective thermal time switch, throttle position switch, etc. Something is telling the computer to turn on the cold start injector when the motor is warm. Ditto for the fuel pressure regulator but much less suspect.
My $0.02
Old Mar 27, 2008 | 05:07 PM
zookdogg's Avatar
Do you have any info or know where I can find any info on what actually tells the cold start injector when to fire and maybe how to check these things?
ladybugRC
458
Aug 21, 2020 10:41 AM
smilen724
13
Nov 8, 2015 04:11 PM
Ditch Doc
Oct 27, 2015 03:20 PM
kcaudill
Oct 10, 2015 02:39 PM
ToyotaMD
Sep 22, 2015 04:49 AM
