3.0 Engine will not heat up
Old Mar 24, 2008 | 03:31 AM
jjenks0's Avatar
My 90 4 runner has the great 3.0 and I have owned it for a couple of years. As my memory is not what it use to be I seem to remember that it use to heat up fairly quickly but for the past winter the I drive 13 miles to work and the needle barely comes off the cold mark. Of course when you shut the engine down and then start it back up the needle is half way because the the cooling system was not active. I replaced the thermostate a month ago and the old one seemed fine and even put cardboard in front of the radiator. The cab heater puts out luke warm air,
I have had the engine out two summers ago to do the famous valve job, took the heater core out last summer because I thought it was leaking but ended up the hoses leading to it were loose. I am wondering if I got some hoses in the wrong place that allows the water to bypass the thermostate.
Anyone got any ideas?
Thanks.
Jenks
Old Mar 24, 2008 | 03:50 AM
Elton's Avatar
did you use a oem t stat ? it should have a little hole drilled on it
Old Mar 24, 2008 | 03:56 AM
jjenks0's Avatar
No I did not. Do you think that would make that big of a difference? I will pick one up today.
Old Mar 24, 2008 | 04:01 AM
Elton's Avatar
so did this problem start with a new t stat ?
Old Mar 24, 2008 | 05:58 PM
purerockfury's Avatar
I had a similar problem w/ my old 4Runner. It had
a 22re in it, but this might work as well.
I drilled a 3/16" hole in my after market thermostat.
Problem was solved. Got great heat and ran perfect.
Or you can buy a dual stage thermostat for like $60.00.
Hope this helps, good luck.
Old Mar 24, 2008 | 06:11 PM
thook's Avatar
I'm almost positive the dual stage/little hole thing/issue is only related to the 22re.
My '92 heats up very quickly, and so should yours....without a dual stage/little hole. Just a regular from NAPA. I've read, and I believe, it's due to the location of the t-stat being right after the radiator and not up on the top where the coolant has a distance to travel and therefore heating up slower. Something to that effect.
Anyway, how old is your water pump?
Old Mar 25, 2008 | 05:03 AM
jjenks0's Avatar
3.0 not heating up
The problem was before the thermostate, may have started when I did the valves and replaced the original thermostate with after market. I think the old one had the hole because I kinda remember thinking that was odd.
I do not know how old the water pump is. Would that make a difference on the engine not getting hot?
Thanks.
Jenks
Old Mar 25, 2008 | 07:50 AM
thook's Avatar
Generally, no. If it doesn't circulate coolant properly, it causes overheating. But, if it's leaking, it can allow air into the system which could cause the thermo to stick open.
However...
Since the thermo is right after the radiator on the 3.0, I'd make sure coolant flowing through the radiator with no air bubbles and that you installed the thermo correctly. And, that it is rated for the correct operating temp.
Old Mar 25, 2008 | 08:20 AM
jjenks0's Avatar
I am guessing the hole goes up on the thermostate.
Old Mar 25, 2008 | 05:32 PM
thook's Avatar
I'm not sure I understand what you're asking. Are you asking how the thermostat goes in? The spring side goes towards the motor, in that case.
Old Mar 26, 2008 | 07:18 AM
jjenks0's Avatar
no, the little hole drilled in the thermostate
Old Mar 26, 2008 | 07:25 AM
thook's Avatar
Still not sure what you mean, but I'll try.
It doesn't matter what position the hole is in....12o'clock, 6o'clock, etc.
bigjstang
Jun 2, 2025 03:56 PM
ZONAYODA
Jul 13, 2015 07:17 PM
Poncho0206
Jul 10, 2015 06:21 PM
Coreyr384
Jul 10, 2015 11:13 AM
Roger Borba II
Jul 9, 2015 05:05 PM
