replaced the dang gasket
Old Mar 25, 2008 | 05:21 AM
Junkers88's Avatar
Folks I got the intake gaskets replaced and the truck runs great. No more miss or freaky idle. Hell I even had to relearn how to take off from a stop light since it's so quiet and smooth now.
Oh I did manage to snap the EGR tube while trying to adjust it but my neighbor had some stainless and he made me a block off plate into the plennum so I could drive to work. The other end is still open where it attaches to the head.
So now two questions.
1) I smell gas, alot. I haven't found any leaks yet and I'm hoping it's a combination of the gas that spilled EVERYWHERE when I pulled it apart and that open EGR thingy.
2) This morning when I went to start it I had to bump it twice before it would fire up and am unsure why.
Thanks again for all the help!!!
Old Mar 25, 2008 | 05:49 AM
Flash319's Avatar
You may be leaking at the injector to rail junction. This is a common problem when you pull the rail off. If it does not sit right the injector will sit on an angle. When it is running look down around the injectors. The 2 bumps to start also points to a leak in the fuel system.
Old Mar 25, 2008 | 05:53 AM
Junkers88's Avatar
You know I did have to pull one injector to get to that little allen head bolt. I wonder if it didn't re-seat properly........
Thanks for the heads up!!!
smthwsn357
May 1, 2024 07:28 AM
Colington
Mar 8, 2020 09:51 AM
Sep 4, 2015 09:27 AM
smiley52
Jul 11, 2015 05:16 AM
87blyota
Jul 10, 2015 04:31 AM
