bad gas milage...help!
Old Mar 27, 2008 | 07:13 AM
flatbedyota's Avatar
ive got a 1986 22re 4wd pick up and when i first bought it, it was stock and it got around 22mpg....well i put a comp 260s cam in it and hedman headers, lifted it 3in and put 33x12.50s on it and it still got about 19-20 mpg...for about the past 7months its been geting progresively worst gas milage it went from 20 to 16 to 14 and now i get about 11mpg and i even downsized to 31x10.50s...its go a fresh tune up new tps sensor and a buddy has a junk truck i took the computer off of, o and a new coolant temp sensor....its starting to idle bad in the morning and it feels extremly sluggish...help! i cant afford to drive my pride and joy anymore (my 83 chevy is gettin better milage)
Old Mar 27, 2008 | 07:15 AM
fishon1213's Avatar
Have you checked the timing?
Old Mar 27, 2008 | 07:27 AM
i can get #1 tdc and all of my marks line up the one on the cam,crank and i pull the cap off and its pointing at #1...i didnt set my base timing right though when i put a new chain and gears on it (did it when i first got the truck) i cant ever figure out wich terminals im supposed to connect and exactly what im supposed to do after i jump them?
Old Mar 27, 2008 | 09:52 AM
also when it is running the exhuast has a strong smell of fuel like its running rich but i pull the spark plugs and they have got an almost white tip like its running lean....this also has me puzled
Old Mar 27, 2008 | 03:24 PM
24Runna's Avatar
Might be a bad o2 sensor.
Old Mar 27, 2008 | 03:28 PM
rvsmichael's Avatar
o2 sensor or maybe bad injector , posssible timing needs adjusted
Old Mar 27, 2008 | 03:48 PM
eightnine's Avatar
id check the o2 sensor and have the fuel injectors clean.. when i installed a new o2 sensor the fuel milage got a lot better instantly
Old Mar 28, 2008 | 06:22 AM
just put a new o2 sensor on it about 3months ago, i pulled it out last night and it lookes ok....i think the timing is off i really dont know how to check it i know you have to jump terminals T and E or something like that to set the base timing but past that i have know idea how to get it right....thanks for all of yalls input!
Old Mar 28, 2008 | 01:46 PM
??....any other ideas??
Old Mar 28, 2008 | 07:10 PM
after i put a new tps sensor on it ran great for about 30 min and it started doing it all over again.....a friend/shade tree mechanic suggested that mabey something in the electrical system spiked the tps and messed it up...could this have happened?
Old Mar 29, 2008 | 02:34 PM
gte718p's Avatar
I fell your pain. I'm fighting the same battle with my truck. From reading the FSM I think the TPS is just a reastat. The procedure for testing it is a simply measuring resistance at different possitions. If you think its in the TPS I would check all the connections and look for chaffed or pinched wires.
Charecter1
Nov 6, 2023 10:08 AM
Eggslinger
Jun 8, 2019 03:32 PM
skoti89
Sep 11, 2015 07:46 AM
pyramid
Jul 30, 2015 10:05 AM
daddio
Jul 18, 2015 10:20 AM
