Running on three cylinders?
Old Mar 22, 2008 | 07:18 AM
Junkers88's Avatar
In my never ending quest to find and fix all my 22re problems I've now found a new one.
I started the diagnosis all over again this morning by starting the truck and trying to guess why it was running like it was. So lets start with spark. I pulled each wire off of it's respective plug one at a time and numbers 1,2 and 3 made a noticable change in the idle (it got worse) number 4 however produced nothing. Not the slightest change in idle. So it looks like number 4 isn't firing. The plugs, cap, rotor, wires etc are all new.
Will a spark plug just stop working?
Thanks in advance guys. I'm trying to avoid tearing into this thing to adjust the valves if I can help it.
Old Mar 22, 2008 | 07:24 AM
toytech76's Avatar
check your valve adjustment. Its really easy to do. If thats the problem and you let it go, it can burn a valve. Factory settings are .008 for intake and .012 for exhaust
Old Mar 22, 2008 | 07:42 AM
thook's Avatar
Sounds like an injector ain't squirtin'.
Old Mar 22, 2008 | 11:36 AM
Junkers88's Avatar
It has GOT to be the valves. I replaced the injector and there's no change so now I have a spare.
I'll have to let the truck cool off and start pulling the valve cover off. God what nightmare...........
Old Mar 22, 2008 | 11:49 AM
dcg9381's Avatar
Put the plug into the wire, does it fire?
If so - check compression on that cylinder.
If good compression, verify injector signal at the plug.
Old Mar 22, 2008 | 02:10 PM
Junkers88's Avatar
Yes it fires.
Compression at 150 just like the other three cylinders
Injector signal? I've got a meter so tell me how to check it.
Thanks.
Old Mar 22, 2008 | 02:15 PM
thook's Avatar
Complete instructions:
http://personal.utulsa.edu/~nathan-b...31injector.pdf
Sleaker
Aug 26, 2020 06:03 AM
jasonty
41
Dec 23, 2018 01:00 PM
Doug4320
Mar 24, 2018 10:11 PM
Sep 4, 2015 09:27 AM
cars-guy
Jul 11, 2015 07:51 PM
