3.0 interference motor?
Old Mar 22, 2008 | 09:29 PM
ernest t bass's Avatar
is the 3.0 v6, 89 to 95 an interference motor?
if the timing belt snaps will it smack valves?
what is the replacement interval?
Old Mar 22, 2008 | 09:35 PM
DeathCougar's Avatar
No, it is not an interference engine.
I would suggest to replace the belt every 75k
Old Mar 22, 2008 | 09:37 PM
thook's Avatar
No and no and approx. every 60k miles.
The 22r series motors were/are interference. If your timing belt snapped, all it would do is quit running. And, 60k is what's recommended, but lots of folks go further than that with no problems. You just have to inspect it every so often. That still doesn't speak for the timing belt pulleys and tensioner, though. They can last for a very long time....several times longer than a belt. Just depends on how old your present ones as to when they'd need replacing. Even then, inspection is the thing to do.
Old Mar 23, 2008 | 10:36 AM
4x4phil's Avatar
What year 3.0 are the same?
I want to know what year parts will fit my 90?
Old Mar 24, 2008 | 11:33 AM
Matt16's Avatar
All 3VZE (3.0L V6 in Toyota trucks) are basically the same. Maybe some differences in vacuum line routing and emissions stuff, but the timing belt is the same (1988?- 1995)
Old Mar 24, 2008 | 11:56 AM
dieselloco427's Avatar
I there is one difference - but not too big - the timing belt is tensioned by a hydraulic tensioner instead of a spring on some years. I think 1993+. Just an fyi...
Old Mar 24, 2008 | 12:08 PM
mr_schuster's Avatar
Good call... I was just trying to think of something different.
Old Mar 24, 2008 | 02:48 PM
thook's Avatar
There are differences....pre 90's... in throttle body styles, distributor design, and...I believe from every one to two years even through the 90's....on switch and sensor connectors. I don't know specifics, though. Too much to keep up with...lol.
If your planning a switcheroo, you'll just have to compare and decide what to keep from the original and what to replace/splice in from the donor. When I swapped a motor from an '89 into my '92, I just ended up with the block from the '89. The head assemblies fit, but since the PO/rebuilder of the '89 messed up the heads in a couple of different ways, I went back to the top end from my '92.
As I recall, the main difference was in TB and distributor design. Probably...on the TB, anyway...because the motor was out of a 5spd and the '92 is an auto with cruise control. So, my '92 TB had an additional dashpot and the TPS connectors were different. The injectors were the same, the ECT sensor was the same, but the sensor cluster housing on the manifold was different.
As I said, too much to keep up with...engh.
Old Apr 6, 2008 | 07:24 AM
well, back to the subject of interference... I read somewhere that If the heads were milled down too far that valves could be bent because there would not be enough "space" for them to open up if the belt snapped or the timing was off...
Old Apr 6, 2008 | 07:28 AM
Team420's Avatar
they would have to be shaved a lot, could happen tho
80Truck
Oct 12, 2025 07:25 PM
Littlerick
Sep 10, 2015 08:57 PM
93toyoguy
Aug 2, 2015 07:41 PM
tobylab
Diesel Swaps
Jul 17, 2015 06:51 PM
Coreyr384
Jul 10, 2015 11:13 AM
