No front drive when in 4X4
Old Mar 22, 2008 | 04:25 PM
thefreqofnature's Avatar
I removed a hub to replace my CV shaft, one of the boots was cut. After I was done and had replaced the hub I no longer have front drive in 4X4. I think it may be something to do with the hub clocking...any ideas? I have autolocking hubs. Thanks
Old Mar 22, 2008 | 08:29 PM
tc's Avatar
tc
Yep, sounds like a hub problem - the open diff won't transfer power if one of the hubs is unlocked (all the "power" will go to the unlocked side).
Old Mar 23, 2008 | 05:57 AM
leebee's Avatar
take it off and check the order of installation, there could be a seating ring in the wrong location not allowing the spring to engage the internals.
lee
Old Mar 23, 2008 | 07:04 AM
lee
Thanks leebee
I know the hub has to go on a certain way...but I can't figure how .
I'll have another look at the spring.
Old Mar 23, 2008 | 07:51 AM
leebee's Avatar
here is a link to the fsm i use:
http://personal.utulsa.edu/~nathan-b...fsm/index.html
look in the suspension and axle section, there is a detailed write-up for your manual locking hubs.
hope this helps.
lee
Old Mar 23, 2008 | 08:17 AM
huntnfreak's Avatar
Just make sure everthing is installed in the right order. I just replaced might left cv axle with auto hubs and the 4x4 works.
Old Mar 23, 2008 | 09:12 AM
hope this helps.
lee
Thanks again! After I read your first reply it dawned on me that I should check the FSM
Old Mar 23, 2008 | 09:22 AM
huntnfreak,
Care to stop by and give me a hand...I'm probably only a couple of thousand miles away. You have described just what happened. I changed my left CV with auto hubs but the 4X4 will not work.
I'm going thru the FSM with an eye on the spring. I think/thought I put everything back in order but obviously something is not right with my thinker. Thanks again everyone I owe you each a
Old Mar 23, 2008 | 01:46 PM
Ok I've studied the FSM and I now have the hub body off the end of the CV. I haven't disassembled the hub and everything is moving around real well. So I'm going to rule out the spring for now. I'm still thinking it has something to do with the clocking/orientation of the hub body to where it mounts.
Can anyone give me additional information on this problem? Thanks in advance!
Old Mar 23, 2008 | 09:43 PM
stormin94's Avatar
Transfer case problems?
Old Mar 23, 2008 | 09:46 PM
Jeenyus04's Avatar
i agree with the clocking suspicion but dont no the right way so im sure someone else will chime in, or you could read in to the fsm a little more..
Old Mar 23, 2008 | 10:10 PM
nix4x4's Avatar
I have manual hubs, so I'm not real familiar with how yours works.
I had the same problem when I bought my truck. I toyed around
with different things for a while. Long story short, during a recent front
brake job done by the PO, a gear was intalled backwards when reinstalling
the driver side hub assembly, causing it not to engage fully.
Old Apr 3, 2008 | 09:01 AM
Well, I read and reread the FSM and put it all back together....still no front drive when in 4hi or 4lo. Any more ideas or suggestions are appreciated.
Old Apr 3, 2008 | 04:43 PM
RobD's Avatar
Do you have ADD on your front axle?
Old Apr 3, 2008 | 06:21 PM
I have auto hubs not ADD.
Old Apr 4, 2008 | 01:07 PM
Originally Posted by yota4runna
If you've installed your hub incorrectly clocked, you've broken one of the ends of the spring. This spring isn't available separately from Toyota.
Both ends of the spring should stick out like this:
If they don't, you need to search out someone parting out some auto hubs, or change over to manual hubs. Too bad. Most of these great auto hubs have been broken just like yours.
NOW WERE TALKING I'll bet you're right on the money! I remember looking at it thinking something's not right there. I'm gonna start looking for those springs. Thanks again!
Jun 1, 2021 01:51 PM
lledwod
Aug 30, 2016 01:03 PM
coryc85
Sep 9, 2015 06:24 AM
Avenged
Jul 9, 2015 07:55 AM
Jnkml
Jul 6, 2015 01:20 PM
