22re Crank and Cam Sensor Locations.
Old Sep 12, 2014 | 07:22 AM
dfarr67's Avatar
Have a 1990 4Runner I have put a turbo on and am using a VEMS standalone ecu. Having a buddy doing the install and although the engine is running it is breaking up above 1500 rpm. He is using the distributor to give both crank and cam signals as I went with cnp LS coils. There are a few issues to be troubleshot but I'm wondering if this configuration is giving enough resolution to the ecu with the dizzy having both a four pint wheel and a single point wheel to run both hall sensors.
The reason I didn't go with a proper crank wheel is the lack of space behind the harmonic, some LC Engineering uses magnets in the outer ring and I think that may be trouble if slippage ever occurred and the fact that I've had belts go before and I wanted access to change the belt without a sensor being in the way at the front of the pulley. I may revisit machining the rear of the harnic if necessary.
Dave
Old Sep 12, 2014 | 01:20 PM
wyoming9's Avatar
Red face
This will be interesting
I have never had a need for those extra sensors on this low horse power engine
Is this something for your stand alone ECU
More then likely you will need to source the sensors from them and build what hardware you need.
also without knowing just what kind of signal or communication protocol you need.
Like I said Interesting!!!
bigjstang
Jun 2, 2025 03:56 PM
sandyota
Feb 4, 2021 11:16 AM
thefishguy77
Jul 30, 2015 10:59 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
bryan34w
Jul 6, 2015 05:53 PM
