dash lights
Old Oct 8, 2014 | 05:27 PM
skeeter0288's Avatar
dash lights
how do your dash brake indicator light and 4wd indicator light work?i am adding a custom dash and I cannot find a power wire for these . they worked before I removed the original dash cluster.
Old Oct 8, 2014 | 09:15 PM
scope103's Avatar
They're powered through the gauge fuse.
The 4wd indicator is grounded through the selector switch and ADD switch in series; wire is Green-Yellow.
The brake light is grounded through the parking brake switch and the brake fluid level switch in parallel. Wire is Green-White.
This is for a '94. Is yours a '94?
Old Oct 12, 2014 | 11:03 AM
mine is an 87. they worked fine until I ntook out the oem dash and created a custom dash. got some small led indicators for the t/s , high beam,4wd and brake indicator. I have identified all wires except for the 4wd and brake indicator.all fuses are good.
ashersullivan88yota
Jan 18, 2022 05:37 PM
ghostmoney
Jan 28, 2018 11:42 AM
AkitaDog
Sep 1, 2015 08:05 AM
ViperTT
Aug 14, 2015 05:27 AM
Johntom240
7
Jul 13, 2015 12:18 AM
