93 22RE won's start
Old Oct 10, 2014 | 12:39 PM
ditypup's Avatar
93 22RE won't start
Hi, I rebuilt my 22RE new rings and bearings. It was running fine when I shut it off last time before pulling the engine. I got the engine installed yesterday and completed the ancillary stuff today.
I just tried to fire it up and it attempts to start and then sounds like a tractor huffing along slowly with the starter turning it, release the starter and it huffs along and dies Wont fire up .
I haven't done a compression check yet, but that looks like what I will do next.
I jumpered TE1 and E1 and the check engine light flashes constantly which I interpret to mean everything is normal. No codes.
I have pressure on the fuel rail because it spewed gas when the fuel line banjo bolt is loosened some.
The last time I overhauled this engine it fired up right away after installation. But that was 12 years ago.
Old Oct 10, 2014 | 01:29 PM
ditypup's Avatar
Ok got it running. I was one tooth off on the distributer install. And I had a bad #4 spark plug. Starts up excellent and seems to run excellent now. I will have to get it out on the road to see for sure. Got to get the timing set first.
Old Oct 10, 2014 | 03:20 PM
ditypup's Avatar
Timing set , runs good , lots of valve noise --- will have to re-adjust the valves here shortly, but it seems to run strong.
bigjstang
Jun 2, 2025 03:56 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
colinmil
Jul 6, 2015 04:03 PM
HRDC0R19
Jul 5, 2015 06:43 PM
CJ94yota
Jul 3, 2015 10:14 PM
