1st gen 4runner leaking gear oil from shifter only
Old 10-06-2014, 06:04 AM
martinezoi's Avatar
So I got home yesterday after a long day of driving all around town. When I was just a few blocks from my house, I notice a smell inside the cab, gear oil. So when I got home, there was a puddle of gear oil underneath the yota. I took a quick peek and saw that it was wet from the top side. I immediately thought it was maybe the transfer case but decided till this morning to remove console from inside to get a better view from atop. when I removed the shifter console I noticed it was wet only around the shifter base particularly around the boot. Now, I did fill the tranny about two months ago with gear oil due to an oil drip I had. Could this have been the tranny puking out the excess gear oil that it may have had? or something else? should I add gear oil? thanks in advance
edit: this a 88 4runner 22re, 5 speed manual
Old 10-06-2014, 06:39 AM
oldblue's Avatar
pull the fill plugs to check the level, that will tell you if you need to add fluid. did you fill it through the fill hole or through the top with shifter removed?
Old 10-06-2014, 07:12 AM
martinezoi's Avatar
I filled thru the shifter. seems like when it puked it out, it got some to the driveshaft down to the diff and also to the top of the transfer case.
Old 10-06-2014, 07:21 AM
toyota4x4907's Avatar
..... is there a reason you didn't fill it through the FILL hole? Its on the side so that you can't fill it with more than needed.
Old 10-06-2014, 07:30 AM
martinezoi's Avatar
I was also changing the shifter seat at the seat with a marlin one
Old 10-06-2014, 07:38 AM
martinezoi's Avatar
just make sure then cause i'm about to do it, do I remove drain plug and if there is oil coming out then that's the excess oil? do I let it drain till it stops?
Old 10-06-2014, 07:44 AM
JasonYota's Avatar
Uh no. You remove the fill plug. The fluid should be up to the fill plug.
Old 10-06-2014, 07:47 AM
martinezoi's Avatar
woops! typo! I meant to say the fill plug...
Old 10-06-2014, 08:06 AM
JasonYota's Avatar
Yes then you are correct
Old 10-06-2014, 08:14 AM
oldblue's Avatar
you most likely just overfilled it and it puked it back out. its much easier to fill through the shifter especially if you have no fluid transfer pump. just make sure you also remove the fill plug on the side when you fill through the shifter to avoid overfilling. i'd remove the fill plug and let the excess drain, clean everything off real good with some brake clean, taker her for a spin, and recheck for leaks. also, a fresh application of some rtv on the shifter base would be a good idea as well.
Old 10-06-2014, 09:16 AM
martinezoi's Avatar
thanks guys, yeah it did have too much oil in there. I drained it thru the fill plug, took her for a good spin (30 min drive). No leaks...
voiddweller
19
05-02-2016 09:10 PM
85run
07-08-2015 11:20 PM
WI Girl
06-25-2015 03:45 AM
Mr.Black
06-21-2015 10:17 AM
newzingo
06-19-2015 04:37 PM
Quick Reply: 1st gen 4runner leaking gear oil from shifter only
