Is this excessive play? Rear pinion flange, with video
Old 09-20-2014, 10:24 AM
Hugh_Mann's Avatar
I have some humming/vibrations coming from the rear end in my 1993 22RE 4wd, so I decided to put her on stands and see what I could find. There seems to be a lot of lateral play at the companion flange. I have zero experience here, but my first thought was maybe the pinion bearing is shot? As well, does my rotational play seem to be okay?
https://www.youtube.com/watch?v=a2vP...ature=youtu.be
Old 09-20-2014, 11:45 AM
dark_fairytales's Avatar
I do agree, that is very excessive play.
Old 09-20-2014, 11:53 AM
millball's Avatar
Drop the drive shaft, remove the nut and then the companion flange.
Install new seal, degrease pinion splines and companion flange.
Lock-tite spline area of companion flange and threaded end of pinion.
I torque the nut to 130-140fp, then stake nut and re-assemble. Flanges on t-case only need 90-95 fp.
I found all the flanges loose like this on my '87 runner when I got it with 273,000mi on the clock.
All still good and tight after 5,000 more miles and vibrations dissappeared.
Always a chance you do have a bad pinion bearing, but you have nothing to lose by trying to tighten your flange.
Old 09-20-2014, 12:05 PM
millball's Avatar
Rotational play does'nt seem excessive for worn parts, considering that the play includes the lost motion of the axle spline clearances and the spidergear to side gear clearances as well as ring and pinion backlash.
Old 09-20-2014, 12:19 PM
Hugh_Mann's Avatar
Thanks for the detailed reply millball. That was also my plan of action. Seeing as my pinion seal is already leaking, I figured tightening up the companion nut when replacing the seal was my best bet. Do you think 130lb-ft for the nut is possibly too much? I've noticed a general anxiety about the crush sleeves used in our diffs.
Old 09-20-2014, 12:25 PM
millball's Avatar
It is my experience that 130-140 fp is not enough to add additional crush.
I have torqued several different ones to these values and the measured preload did not increase as I increased the tightness, and they continued in satisfactory service.
Old 09-20-2014, 07:01 PM
Hugh_Mann's Avatar
After removing the companion flange, I found a crazy amount of up/down, in/out play in the pinion. I'm not sure if just the pinion bearing is shot or if the damage runs deeper. I think I might try to find a used third to swap in and maybe pull this one and do a rebuild. Here's another video:
Old 09-20-2014, 08:45 PM
millball's Avatar
I cannot see your video, but you cannot make any judgement by wiggling the pinion with no tension applied to it.
Put the flange back on and torque it.
Then lets see what you've got.
Old 09-21-2014, 04:05 PM
Hugh_Mann's Avatar
Okay, that does make sense seeing as the pinion nut sets tension to the pinion.
I took it all apart, had a hell of a time getting the new seal in, put the flange back on and tightened the nut 3/16 of a turn tighter than it was before. I believe it was between 110-120lb-ft. This was enough to take all the slack out of the flange, and I like to err on the side of caution anyways.
I guess time will tell if I fixed the leak. I'm still hearing noise from the rear, but it could be a number of things. Thanks for your help.
Old 09-21-2014, 04:17 PM
millball's Avatar
Please post back to this thread after you run her a while.
It is always helpful to know whether a fix holds up or if other measures have to be taken.
Old 01-01-2015, 11:56 AM
Hugh_Mann's Avatar
Quick update. I ran the re-tightened pinion flange for a few months without issue. Additional torque to the pinion nut didn't seem to affect the crush sleeve. It seems as though the pinion nuts can readily handle 130 lb-ft as millball suggested. I've since replaced my stock 4.10 diffs with 4.56 units.
Best of luck y'all, and don't be scared to torque down those nuts!
Old 01-01-2015, 12:07 PM
millball's Avatar
Appreciate the update. Happy New Year!!
the1998sr5
15
07-14-2020 08:35 PM
Yotadawgjr
10
08-23-2015 10:51 AM
calderp
07-27-2015 09:58 AM
Hamonacracker
07-17-2015 08:33 AM
Kalihi,HI
07-09-2015 04:29 PM
Quick Reply: Is this excessive play? Rear pinion flange, with video
