22RE idle surging/hesitation
Old Oct 8, 2014 | 08:57 AM
helidriver's Avatar
Just rebuilt an extra engine I picked up a couple years ago from ground up. 22re. Swapped my tired old one for it in my 87 runner Sr 4x4. Got it fired up and mostly tuned then took it to toyota to fine tune it.
The guy there said it's timed, valves adjusted, vacuum hoses good, no leaks, tps adjusted.... BUT it's idling at about 1000 no matter what I do, it's rough acceleration but cruises fine, and it surges from time to time at idle.
This sounds like tps right? Any other thoughts of what it could be. Drove it 2k since the rebuild ever towed a uhaul with about 2k from vegas to Portland and it's not leaking a thing? Did the Toyota guy screw up the tps adjustment? He acknowledged the problems and blamed it on old gas from while I was rebuilding varnishing the cylinders but that sounds stupid with what these trucks can do.
Old Oct 8, 2014 | 08:21 PM
abecedarian's Avatar
TPS is pretty easy to check- put the jumper in the diagnostic connector, and if the idle doesn't change after doing that, the TPS is 'probably' not set right.
Otherwise, common causes of 'hunting' idle speeds are vacuum leaks. It's an '87 so maybe the check valve on the brake master cylinder isn't right; PAIR and the warm-up / idle-air control may be suspect as well.
Idle-up on the power-steering pump, and if you have air-conditioning there's an idle-up valve on that too: those could be suspect.
Old Oct 8, 2014 | 10:12 PM
helidriver's Avatar
Other symptom is "hard" lugging up and down when ur just driving around slow giving it easy gas and letting it off. Jumping the connector does change the idle sound.
montanatruck
Feb 26, 2017 07:07 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
jake_v
Jul 22, 2015 03:17 PM
kcaudill
Jul 20, 2015 12:06 PM
kyletbert
Jul 17, 2015 11:39 AM
