Why not use Rad hose for ISR mod?
Old Jan 28, 2007 | 09:45 AM
DCS's Avatar
DCS
Hi, I bought a '90 4runner 3.0 a while back. Just starting to dink with it.
The ISR mod is my next project: a piece of pipe installed between airbox and plenum using 2.5" radiator hose couplers.
I was wondering if I couldn't find a 45? radiator hose from a tractor or something, cut it to fit, install nipples with washers on the inside and outside and a sealer or glue applied, and call it good?
For air intake, a rad hose will certainly last as long as the couplers used in the pipe version of the mod. It would be simpler to perform, and would eliminate the restricted access to dipsticks described by some modders.
Has anybody tried the mod with 2.5" hose? Got tips for a rad hose that is a good fit?
Other thoughts?
Thx!
Old Jan 28, 2007 | 10:17 AM
95RunnerSR5's Avatar
i was thinking of that but at almost $20 a foot, i opted for 2 feet of 3" inside diameter of alumnium pipe for the same price.
Old Jan 28, 2007 | 10:38 AM
DCS's Avatar
DCS
OHHHHHHHHHHHHH!
See, that answers my question perfectly!
I had no idea radiator hose would cost more than a buck or 2 per foot.
$20/ft! Cowabunga!
Old Jan 28, 2007 | 10:52 AM
Elton's Avatar
think the rad hose would compress under load and not work
Old Jan 28, 2007 | 10:55 AM
yup...if someone around you has a mandrel bender you can buy the aluminum pipe off ebay for $20 shipped and have it bent to your needs! or if nobody close has one, do what i did and cut it into 2 pieces and use rubber connectors to piece it together.
128keaton
Sep 14, 2015 12:16 AM
Peevedkitten
11
Aug 31, 2015 06:57 PM
WellsR
12
Jul 31, 2015 03:27 PM
Massmayhem247
Jul 18, 2015 05:46 AM
the1998sr5
Jul 16, 2015 06:20 AM
