Engine still won't come out!!!!!!!
Old Feb 1, 2007 | 09:38 AM
mtrdrms's Avatar
So I have my 22re totally unbolted and disconnected from the tranny but it still wont come out!?!?!? They are about an inch apart from each other and loose but just not coming apart. I have a theory but I still dont know how to remove this dam thing! My guess is that the pilot bushing or bearing is siezed to the input shaft on the tranny and its not allowing the input shaft to come through the clutch and pressure plate that is still bolted to the flywheel. So what should I do?
Old Feb 1, 2007 | 09:47 AM
Marc's Avatar
I once had to use 2 hydraulic bottle jacks to remove a tranny with a siezed pilot bearing.
If you try it make sure you apply even pressure and that EVERYTHING is unbolted.
Old Feb 1, 2007 | 09:51 AM
mudbutt's Avatar
I've used a tow strap on the output of the t-case. I then when to the back of the vehicle and straped myself up. slamed my fat but against the strap untill the tranny fell free. I supported the tranny with ratchet straps across the framerails.
Have Fun
Old Feb 1, 2007 | 10:42 AM
mtrdrms's Avatar
Where did you put the bottle jacks?
Old Feb 1, 2007 | 12:12 PM
Marc's Avatar
It was 30 years ago so I can't remeber exactly but I think there was something on the engine or chassis that I used.
It wasn't a 4runner.
Old Feb 1, 2007 | 12:39 PM
dcg9381's Avatar
Jack up the tranny, get the stress off the transmission input.
Use a load leveler.
Wiggle.. Wiggle the motor while pulling.
Old Feb 1, 2007 | 01:07 PM
mtrdrms's Avatar
Use a load leveler.
I have been doing this for 3 days! I really dont want to bolt the tranny back up and pull them together but dam if thats not the way its lookin'.
Old Feb 1, 2007 | 01:35 PM
dcg9381's Avatar
I don't think it's likely that the pilot bearing seized if you've already moved it out an inch. You don't want to pry on it, but at this point if you've got it setup so that the input shaft isn't binding on anything, you could carefully pry at the top and sides of the motor (where the mounts are solid).
A load levler is important, as it's easy to pinch the tranny input.
I dunno what else to tell you.. It's it free 1" all the way around? Or more free at the top, bottom, side, etc?
Old Feb 1, 2007 | 01:51 PM
mt_goat's Avatar
Try renting a tranny jack, its usually so much easier with the right tools. I found this attachment to a floorjack works great and was only about $50:
sandyota
Feb 4, 2021 11:16 AM
Doug4320
Mar 24, 2018 10:11 PM
Tykiller1994
Aug 10, 2015 07:49 PM
hangtown88toy
Jul 10, 2015 02:33 PM
raiderhawks00
Jul 8, 2015 06:23 PM
