Steve's PCV valve mod
Old Jan 30, 2007 | 06:31 AM
Babypig's Avatar
I couldn't take trying to get to the PCV valve any longer so I modded the one the comes from the valve cover.
This also makes it easier to add an oil catch can if desired to keep oil out of the intake and gumming up things like the IAC etc.
Hope this helps out a little.
Old Jan 30, 2007 | 06:55 AM
chimmike's Avatar
Where IS the pcv valve on the 3vze anyways? I've had a new one sitting in my back seat for weeks because I couldn't find the ˟˟˟˟˟˟˟ thing.
Old Jan 30, 2007 | 07:29 AM
Babypig's Avatar
On the passengers side valve cover under the intake.
Old Jan 30, 2007 | 08:27 AM
Bumpin' Yota's Avatar
I did that exact mod about 2 years ago and got it from one of the posters here who came up with it long before I did it. My drill bit also broke off inside of the PCV valve when I was drilling it out. Quite the PITA to get it all out...
https://www.yotatech.com/forums/show...ght=valve+lash
ps - dont use clear tubing, I didnt even risk it and got the proper tubing for underhood operation.
To anyone doing this mod there is a tripup. That tripup is the difference in sizes on both sides of the PCV valve. The bottom of the valve is 1/2" or so while the top is about 5/16" or so. So you will need to run 1/2" from the remote PCV to the old drilled out one, and place a small bit of 5/16" hose over the old PCV's top so you have something to clamp the 1/2" hose to.
but good mod and its good to bring it to the top for the newguys signing on!
Old Jan 30, 2007 | 09:40 AM
Babypig's Avatar
That was probably me but i just found the pics again and decided to post it again. Yeah forgot about the different sizes of tube. I made what i had work.
smthwsn357
May 1, 2024 07:28 AM
he's gone
7
Dec 3, 2019 07:08 AM
Eggslinger
Jun 8, 2019 03:32 PM
Massmayhem247
Jul 18, 2015 05:46 AM
