fuel tank needs cleaning
Old Jan 29, 2007 | 06:27 PM
jimtanner's Avatar
Does anybody know anything that will get rust/varnished out of my gas tank???????????????????????????????? THANK YOU
Old Jan 29, 2007 | 09:49 PM
Five1Nine8Eight's Avatar
Have you looked into POR 15?
Old Jan 29, 2007 | 11:57 PM
DeathCougar's Avatar
I wouldn't use POR-15 inside a gas tank.
Old Jan 30, 2007 | 12:26 AM
Worked great in my 30yr old tank...
http://www.por15.com/s.nl/it.A/id.1515/.f
Old Jan 30, 2007 | 06:06 AM
jht3's Avatar
i hear E85 gas will work pretty well
seriously, don't put E85 in your truck. it'll do bad things to your pump and seals. Eastwood company sells a gas tank kit, as does POR-15.
Old Jan 30, 2007 | 06:23 AM
4runnerD's Avatar
POR15 actually makes a tank liner which is supposed to be a lot better than Kreem...?
the machine shop I use will put gas tanks into the same tank that they boil the engine blocks in... does get rid of the rust but will get the varnish and sludge.
Old Jan 30, 2007 | 06:27 AM
chimmike's Avatar
Seafoam (if the tank is still in your ride)
run a full can of seafoam for a full tank of gas, 3 times in a row. that should break up all the crap nicely.
Old Jan 30, 2007 | 07:11 AM
MMA_Alex's Avatar
if you're looking to get rid of the rust/varnish permanantly i'd get the por-15 gas tank kit thingy. rust is gunna be hard to get out, but por-15 is good at covering up rust, and creates a layer that will not rust through. the varnish you can probably get out with various solvents.
Old Jan 30, 2007 | 06:16 PM
jht3's Avatar
also, a radiator shop can boil your tank. this of course requires you remove your tank. once it's boiled out, you can use one of the sealant kits
Old Jan 31, 2007 | 04:02 AM
maxpower_hd's Avatar
The POR_15 tank kit works well. I used it on a rusted motorcycle gas tank and it worked great.
Eggslinger
Jun 8, 2019 03:32 PM
Doug4320
Mar 24, 2018 10:11 PM
skoti89
Sep 11, 2015 07:46 AM
pyramid
Jul 30, 2015 10:05 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
