For those with Turbos, Best exhaust setup???
Old Feb 1, 2007 | 04:38 PM
swerks's Avatar
Smile For those with Turbos, Best exhaust setup???
Best set up for ct 20, how do you secure down pipe if you dont use the original bracket?? any other info would be good, muffler suggestions etc.
Old Feb 1, 2007 | 05:33 PM
dcg9381's Avatar
For a turbo, the best exhaust setup is the least resistant exhaust setup.
As you've got a CT20, match the diameter of the outlet of that turbo to the diameter of the pipe you use.
I'd suggest that you don't secure the turbo to the engine/transmission, instead, use a piece of flex tube, close to the downpipe. This helps to keep the ct20 housing from cracking (and racking up $$$ repair bills)
This is the sort of thing I'm talking about:
For a muffler, a simple, low cost, low restriction muffler works great. You can go nuts with flowmaster or any design you want - but typically generic "turbo" mufflers work just fine.
82yodahickman
34
May 16, 2017 01:00 PM
God's Bounty Hunter
Oct 23, 2015 09:44 AM
RatOmeter
Oct 22, 2015 03:17 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
