Installed a lce short shifter and now can't put in gear
Old 08-06-2016, 03:50 PM
lalojamesliz's Avatar
Before I installed the short shifter my trans would sometimes give me a small problem putting it in 1st or 4th gear like if something was blocking them and I had to force it in gear.
Every other gear was fine.
Now that I installed the short shifter I can put it in 3rd if I really try to. The clutch system has a new slave cylinder, new fluid, was bled, no leaks and the clutch pedal support has no cracks.
Lce is closed until Monday but can you guys help?
Old 08-07-2016, 01:18 AM
wyoming9's Avatar
Is it the correct shifter for the transmission you have ??
New or used shifter??
They are different .
New Bushing and socket ??
You do realize it could be bearing wear in the transmission causing the shifting problem.
You should never have to force anything
Old 08-07-2016, 08:16 AM
Yes it's the correct one. The bolt pattern on the aluminum plate fit perfect. It's new.
I am using the included new bushing and socket.
When I first got the truck I thought it was just the fluid that had to be changed in the Trans so I put some mt90 in and still had the small problem with 1st and 4th.
Then I changed the slave cylinder, fluid and bled the system and still had the problem.
So I thought of the bushing and socket so I bought this shift kit since it included them but now I can't drive it wtf man
Old 08-08-2016, 10:48 AM
Called Lce and thank to them I found out I had the wrong shifter bushing ( my mistake). I haven't driven my truck yet but it shifts into gear perfect while parked. I couldn't do that before. I'll drive it soon
stanz
03-25-2016 10:47 AM
Charchee
03-21-2016 06:10 PM
Yotadawgjr
02-10-2016 08:44 PM
BUDD
02-08-2016 12:53 AM
YoterTillDeath
07-04-2002 03:13 PM
Quick Reply: Installed a lce short shifter and now can't put in gear
