The Guy at Toyota said I can use between 1986- 1992?
Old 07-23-2016, 01:07 PM
Diego toyota's Avatar
Fuel pump bracket needs to be replaced. I have a 91 toy 22re. My question is. What other years can I use, if I was to find a used fuel pump bracket? The rep at the dealer said from 1986- 1992. Does this sounds correct? Thanks.
Old 07-25-2016, 07:26 AM
Flash319's Avatar
The bracks will all bolt up but the lengths change depending on the tanks size. Also the electrcal conectors will be different from pre 88 to 89-95.
Old 07-25-2016, 10:34 PM
Staff
Terrys87's Avatar
Tanks differ between 2 and 4 wheel drives and also by each generation. Since you have a 91 you can use 89-95 but even then there can be some differences. Pay attention to the length of the bracket that holds the pump. The 85-88 metal hoses coming off of the tank are not as long as the 89-95. It probably could be made to work but you really need to get the correct assembly for your truck.
Old 07-26-2016, 06:37 AM
scope103's Avatar
Terrys87 describes the issue well. Here's what I said in Diego_toyota's other thread:
https://www.yotatech.com/forums/f116.../#post52328786
Stuarrt
05-08-2016 04:41 PM
some drunk guy
04-07-2016 08:43 PM
geoduke
03-25-2016 05:30 PM
jiggseob
03-23-2016 04:20 AM
Joey22r
02-27-2016 04:24 PM
Quick Reply: The Guy at Toyota said I can use between 1986- 1992?
