Cam lobes wiped bad, need opinion on Rockers
Old Jul 17, 2016 | 09:37 PM
Old Red 94's Avatar
Hi guys,
I just got an annoying tick that started on my way home from work on friday in my 94 22re pickup. Long story short I just did a top end rebuild, all toyota gaskets, new head, aisin oil and water pump, etc. I left the bottom end alone because I had great compression, 169,170,168, 169 on all cylinders, so I left well enough alone obviously. I have 500 miles on this, and this afternoon pulled the valve cover to check head bolt torque, and found my brand new cam was wiped like a mother.
Now before you say user error, know that this is not my first rodeo with a 22re, and that this cam was broken in properly valves set to proper gap for that specific cam, etc. I am in contact with who I got the cam from, but my question now turns to my rocker arms. I had the OEM rockers resurfaced at a highly reputable machine shop in the area, and am now wondering if they are now toast because of the cam taking a crap?
At this point I am just sick to my stomach, but would like to know when a cam wipes, are the rockers usually toast as well?
Old Jul 17, 2016 | 11:59 PM
wyoming9's Avatar
The best answer is maybe ??
You have them there in front of you .
Just what do they look like??
Worn so hard no material left to clean up ??
If your in doubt replace them.
Seems like quite a few soft cams around as of late
Old Jul 18, 2016 | 06:04 AM
fierohink's Avatar
How many loves are trash? Is it just one? If so maybe the rocker seized a bit and wore down the love or poor hardening on the cam caused the rocker to fail.
You can take your rocker bridge assembly apart and replace a single rocker if that is the case.
Why did you have your rockers resurfaced in the first place? They are cheap enough to replace as opposed to grinding on them hoping the heat treating and polish remains.
Old Jul 18, 2016 | 06:06 AM
fierohink's Avatar
Rock auto has rockets for like $10
Naked Runner
Feb 16, 2016 05:36 PM
BK2TFUTURE
Feb 9, 2016 09:45 AM
95YOT
Feb 9, 2016 02:14 AM
Joey22r
Feb 8, 2016 05:08 PM
Toddski
Jul 19, 2002 10:47 PM
