twin stick in a 88
Old Jul 17, 2016 | 03:36 PM
az1320's Avatar
twin stick in a 88
I have a 88 pick up 22re 5spd and I would like to but a twin stick case into my truck so I can run 2lo. is this possible? if so what is involved?
part 2 of that is I would like to run a 4.7 gear in the case. do the older twin stick cases accept the 4.7 gear swap?
Old Jul 17, 2016 | 04:01 PM
cbr600rx7's Avatar
What transfer case are you currently running? Forward or top shift? Gear or chain driven? If you know the response to the above questions it will help you a lot.
Old Jul 17, 2016 | 08:45 PM
az1320's Avatar
it is a top shift. shy of that I do not know anything else about it. I have looked for ID markers on it but I can not find anything.
Old Jul 18, 2016 | 05:05 AM
dropzone's Avatar
Fossilized
if it is a top shift you can run twin sticks
i had the Front Range Twin Stick
you will need to pull your transfer case to do the install
http://www.4x4wire.com/toyota/tech/twin_stick/
the twin stick doesn't care what set of gears you are running in the t/c
Old Jul 18, 2016 | 06:58 AM
az1320's Avatar
dropezone that kit is awesome.
Old Jul 19, 2016 | 11:45 AM
az1320's Avatar
Cbr600 did you have any input?
Joey22r
Feb 23, 2016 10:16 PM
ZRTALPHA1
Feb 21, 2016 12:12 PM
postawkwardkid
Feb 19, 2016 12:30 PM
mgklee
Feb 18, 2016 12:47 PM
Bighead
Jul 27, 2002 02:39 PM
