1994 pickup 4x4 frame replacement question
Old Jul 28, 2016 | 02:16 PM
doc702's Avatar
Hi guys, my 94 pickup 4x4 manual SWB regular cab's frame is messed up bad. I need to replace the frame but checking out my local junkyards in las vegas recently turned up nothing for me. There is a lot of 4runners in the local junkyards but just not sure what frames are interchangeable with my pickup. Can anyone tell me which vehicle models are an exact match to my pickup if any? Any help would be great. Thanks in advance.
Old Jul 28, 2016 | 06:06 PM
Flash319's Avatar
4runners are different frames. Front section is similar but the back is different due to the body mounts and read coil spring suspension. You are closer by going back a model to the 86-87 frame. Other then that you will have to find a 89-95 reg cab frame.
SueLu
Feb 24, 2016 08:23 PM
HappyAdventure
Feb 20, 2016 06:32 PM
BarefootGeologist
Feb 15, 2016 06:01 AM
